주요 콘텐츠로 건너뛰기
Nokia 8265 Logic Board Replacement
필요한 것
  1. Nokia 8265 Logic Board Replacement, Logic Board: 1 단계, 이미지 1개 중 1개
    • Start by removing the face plate of the phone with a plastic tool.
    • Once plastic tool is wedged into the side of the phone, twist and leverage the face plate off.
  2. Nokia 8265 Logic Board Replacement: 2 단계, 이미지 1개 중 1개
    • Once the face plate is off, you will have exposed the keypad.
  3. Nokia 8265 Logic Board Replacement: 3 단계, 이미지 1개 중 1개
    • Simply remove the keypad from on top of the phone, and place it off to the side, leaving just the phone itself remaining
  4. Nokia 8265 Logic Board Replacement: 4 단계, 이미지 1개 중 1개
    • Taking a very small screwdriver, carefully unscrew the six screws attaching the top layer of the screen from the body of the phone.
    • Make sure to remember what screw goes where.
  5. Nokia 8265 Logic Board Replacement: 5 단계, 이미지 1개 중 1개
    • Once the six screws are removed, you may take off the screen section of the phone, exposing the inner workings of the cell phone.
    • The screen section will be able to be removed after Step 4 is finished.
  6. Nokia 8265 Logic Board Replacement: 6 단계, 이미지 1개 중 1개
    • Be careful when removing the Logic Board from the body, lifting it with fingers on both sides to prevent damage of the Logic Board.
    • Separate the Logic Board from the main body of the device.
  7. Nokia 8265 Logic Board Replacement: 7 단계, 이미지 1개 중 1개
    • Insert in the replacement Logic Board, setting the Logic Board carefully back into place.
  8. Nokia 8265 Logic Board Replacement: 8 단계, 이미지 1개 중 1개
    • Set the screen carefully over the body of the phone, avoiding any sliding on the Logic board
  9. Nokia 8265 Logic Board Replacement: 9 단계, 이미지 1개 중 1개
    • Replace screws in the corresponding slots, tightening them till they are not loose.
  10. Nokia 8265 Logic Board Replacement: 10 단계, 이미지 1개 중 1개
    • Replace keypad onto the device
  11. Nokia 8265 Logic Board Replacement: 11 단계, 이미지 1개 중 1개
    • Lastly, you can place the cover onto the phone. You will know when it is in place if you hear a click after placing it in.
결승점
작성자
7다른 기여자 명과 함께
Jack
회원 가입일: 04/20/12
1 평판
안내서 4개를 작성함
SUNY Cortland, Team 1-1, Getto Spring 2012 SUNY Cortland, Team 1-1, Getto Spring 2012 회원
SUNYCORT-GETTO-S12S1G1
2 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 1,295
