이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Start by removing the face plate of the phone with a plastic tool.
Once plastic tool is wedged into the side of the phone, twist and leverage the face plate off.
Simply remove the keypad from on top of the phone, and place it off to the side, leaving just the phone itself remaining
Taking a very small screwdriver, carefully unscrew the six screws attaching the top layer of the screen from the body of the phone.
Once the six screws are removed, you may take off the screen section of the phone, exposing the inner workings of the cell phone.
Insert in the replacement Logic Board, setting the Logic Board carefully back into place.
Set the screen carefully over the body of the phone, avoiding any sliding on the Logic board
Replace screws in the corresponding slots, tightening them till they are not loose.
Lastly, you can place the cover onto the phone. You will know when it is in place if you hear a click after placing it in.
