주요 콘텐츠로 건너뛰기
Nokia 8290 Adhesive White Film Replacement
필요한 것
  1. Nokia 8290 Adhesive White Film Replacement, Front Cover: 1 단계, 이미지 1/3 Nokia 8290 Adhesive White Film Replacement, Front Cover: 1 단계, 이미지 2/3 Nokia 8290 Adhesive White Film Replacement, Front Cover: 1 단계, 이미지 3/3
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Nokia 8290 Adhesive White Film Replacement, Circuit Board: 2 단계, 이미지 1/3 Nokia 8290 Adhesive White Film Replacement, Circuit Board: 2 단계, 이미지 2/3 Nokia 8290 Adhesive White Film Replacement, Circuit Board: 2 단계, 이미지 3/3
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  3. Nokia 8290 Adhesive White Film Replacement: 3 단계, 이미지 1/3 Nokia 8290 Adhesive White Film Replacement: 3 단계, 이미지 2/3 Nokia 8290 Adhesive White Film Replacement: 3 단계, 이미지 3/3
    • Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly.
    • Rotate the faceplate away from the circuit board.
    • Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
  4. Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: 4 단계, 이미지 1/3 Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: 4 단계, 이미지 2/3 Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: 4 단계, 이미지 3/3
    • Hold the faceplate with the adhesive film facing upwards.
    • Use the spudger to pry the adhesive film away. This can be done by working the tool back and forth underneath the film.
    • It is easiest to begin in the upper left corner.
  5. Nokia 8290 Adhesive White Film Replacement: 5 단계, 이미지 1/3 Nokia 8290 Adhesive White Film Replacement: 5 단계, 이미지 2/3 Nokia 8290 Adhesive White Film Replacement: 5 단계, 이미지 3/3
    • Continue to loosen the film with the spudger.
    • Once the film has been mostly loosened, you can peel away the film.
    • Once the film has been removed, the microphone may fall out, if so, place it aside until all other repairs are finished.
결론
Austin Culberson
회원 가입일: 10/22/12
87 평판
안내서 5개 작성하였습니다
Clemson, Team 15-3, Benson Fall 2012 Clemson, Team 15-3, Benson Fall 2012 회원
CLEM-BENSON-F12S15G3
3 회원들
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 357
