소개
Installing a new vibration component is necessary when the vibrate mode on your phone is no longer functioning properly. Installation requires no prior knowledge of mobile phone vibrators.
필요한 것
Locate the small button on the top of the phone.
Depress the button.
With your other hand, pull the front cover away from the phone.
Remove all six 5.3 mm long T6 screws.
Remove the circuit board/faceplate sub-assembly from the back of the phone.
다른 2명이 해당 안내서를 완성하였습니다.
