주요 콘텐츠로 건너뛰기
Nokia 8390 Motherboard Replacement
필요한 것
  1. Nokia 8390 Motherboard Replacement, Back Cover: 1 단계, 이미지 1/1
    • Locate the button on the bottom of the back cover.
  2. Nokia 8390 Motherboard Replacement: 2 단계, 이미지 1/3 Nokia 8390 Motherboard Replacement: 2 단계, 이미지 2/3 Nokia 8390 Motherboard Replacement: 2 단계, 이미지 3/3
    • Depress the button with your finger.
    • While the button is depressed, slide the back cover off of the phone.
  3. Nokia 8390 Motherboard Replacement, Outer Case: 3 단계, 이미지 1/3 Nokia 8390 Motherboard Replacement, Outer Case: 3 단계, 이미지 2/3 Nokia 8390 Motherboard Replacement, Outer Case: 3 단계, 이미지 3/3
    • Grasp the top and bottom of the front cover.
    • Grasp the phone body with your other hand.
    • Lightly pull the casing off of the phone.
  4. Nokia 8390 Motherboard Replacement, Keypad: 4 단계, 이미지 1/3 Nokia 8390 Motherboard Replacement, Keypad: 4 단계, 이미지 2/3 Nokia 8390 Motherboard Replacement, Keypad: 4 단계, 이미지 3/3
    • Lightly peel the keypad off of the phone.
  5. Nokia 8390 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/3 Nokia 8390 Motherboard Replacement, Motherboard: 5 단계, 이미지 2/3 Nokia 8390 Motherboard Replacement, Motherboard: 5 단계, 이미지 3/3
    • Locate the six star-shaped screws on the phone.
    • Note: There are two on the bottom end, two in the middle, and two on the top end.
    • Remove these screws using the screwdriver.
  6. Nokia 8390 Motherboard Replacement: 6 단계, 이미지 1/3 Nokia 8390 Motherboard Replacement: 6 단계, 이미지 2/3 Nokia 8390 Motherboard Replacement: 6 단계, 이미지 3/3
    • Grab the top and bottom of the phone casing.
    • Carefully pull the motherboard apart from the bottom casing.
    • The circuit board should be divided into two parts.
  7. Nokia 8390 Motherboard Replacement: 7 단계, 이미지 1/3 Nokia 8390 Motherboard Replacement: 7 단계, 이미지 2/3 Nokia 8390 Motherboard Replacement: 7 단계, 이미지 3/3
    • Grab the top and bottom of the remaining casing.
    • Carefully pull apart the casing from the circuit board.
  8. Nokia 8390 Motherboard Replacement: 8 단계, 이미지 1/1
    • The circuit board should be divided into three parts, completely separate from the back casing, as shown.
결론
Clinton
회원 가입일: 10/22/12
57 평판
안내서 7개 작성하였습니다
Clemson, Team 14-5, Benson Fall 2012 Clemson, Team 14-5, Benson Fall 2012 회원
CLEM-BENSON-F12S14G5
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 13
전체 시간: 494
