주요 콘텐츠로 건너뛰기
Nokia Asha 201 Audio Jack Replacement
필요한 것
  1. Nokia Asha 201 Audio Jack Replacement, Audio Jack: 1 단계, 이미지 1/1
    • Remove the white case by popping apart the front and back with your finger.
  2. Nokia Asha 201 Audio Jack Replacement: 2 단계, 이미지 1/1
    • Remove the battery by taking it out with your fingers.
  3. Nokia Asha 201 Audio Jack Replacement: 3 단계, 이미지 1/1
    • Remove the two 5.5mm screws by using the T6 screwdriver.
  4. Nokia Asha 201 Audio Jack Replacement: 4 단계, 이미지 1/1
    • Use the blue plastic opening tool to remove the front of the white case.
  5. Nokia Asha 201 Audio Jack Replacement: 5 단계, 이미지 1/1
    • Remove the keyboard using your fingers and set aside.
  6. Nokia Asha 201 Audio Jack Replacement: 6 단계, 이미지 1/1
    • Unscrew the two 5.5mm screws near the bottom of the device on either side using the T6 screwdriver.
  7. Nokia Asha 201 Audio Jack Replacement: 7 단계, 이미지 1/1
    • Separate the black plastic internal case from the screen by prying with the blue plastic opening tool.
  8. Nokia Asha 201 Audio Jack Replacement: 8 단계, 이미지 1/1
    • The black plastic cover should now be separated from the motherboard. Replace the audio jack by removing it with your fingers.
결론
Betsy Walker
회원 가입일: 10/10/19
157 평판
안내서 1개 작성함
USF Tampa, Team S1-G3, Leahy Fall 2019 USF Tampa, Team S1-G3, Leahy Fall 2019 회원
USFT-LEAHY-F19S1G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 13
전체 시간: 185
