주요 콘텐츠로 건너뛰기
Nokia Classic 2600c-2b Battery Replacement
필요한 것
  1. Nokia Classic 2600c-2b Battery Replacement, Battery: 1 단계, 이미지 1/2 Nokia Classic 2600c-2b Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Nokia Classic 2600c-2b Battery Replacement: 2 단계, 이미지 1/1
    • Remove the back cover to expose the battery.
  3. Nokia Classic 2600c-2b Battery Replacement: 3 단계, 이미지 1/2 Nokia Classic 2600c-2b Battery Replacement: 3 단계, 이미지 2/2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
    • Follow the instructions in reverse order to reassemble the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ian VanZandt
회원 가입일: 02/14/12
654 평판
안내서 5개 작성하였습니다
James Madison, Team 3-1, Klein Spring 2012 James Madison, Team 3-1, Klein Spring 2012 회원
JMU-KLEIN-S12S3G1
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 6
전체 시간: 705
