주요 콘텐츠로 건너뛰기
Nokia Classic 2600c-2b Display Screen Replacement
필요한 것
  1. Nokia Classic 2600c-2b Display Screen Replacement, Replacing Display Screen: 1 단계, 이미지 2개 중 1개 Nokia Classic 2600c-2b Display Screen Replacement, Replacing Display Screen: 1 단계, 이미지 2개 중 2개
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Nokia Classic 2600c-2b Display Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the back cover to expose the battery.
  3. Nokia Classic 2600c-2b Display Screen Replacement: 3 단계, 이미지 2개 중 1개 Nokia Classic 2600c-2b Display Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
  4. Nokia Classic 2600c-2b Display Screen Replacement: 4 단계, 이미지 2개 중 1개 Nokia Classic 2600c-2b Display Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
  5. Nokia Classic 2600c-2b Display Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the faceplate with the number pad attached.
  6. Nokia Classic 2600c-2b Display Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
  7. Nokia Classic 2600c-2b Display Screen Replacement: 7 단계, 이미지 2개 중 1개 Nokia Classic 2600c-2b Display Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the six screws positions along the edges of the motherboard.
    • Unscrew the six screws using the Torx 5 screwdriver (see Introduction for description of a Torx 5 screwdriver).
    • CAUTION! Place the screws in a secure location.
  8. Nokia Classic 2600c-2b Display Screen Replacement: 8 단계, 이미지 2개 중 1개 Nokia Classic 2600c-2b Display Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Locate the orange ribbon tape connecting the metal display plate to the motherboard.
    • Lift the black latch attaching the tape to the motherboard.
    • Gently pull the tape out of the latch slot to remove the metal display.
  9. Nokia Classic 2600c-2b Display Screen Replacement: 9 단계, 이미지 2개 중 1개 Nokia Classic 2600c-2b Display Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, gently pry off the motherboard from the plastic shell.
    • CAUTION! When pulling the motherboard out, be careful not to damage the battery under the lower left hand corner of the motherboard.
  10. Nokia Classic 2600c-2b Display Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Gently pull the orange ribbon tape up to remove the display.
    • Replace display screen.
    • Follow the instructions in reverse order to reassemble the phone.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ian VanZandt
회원 가입일: 02/14/12
699 평판
안내서 5개를 작성함
James Madison, Team 3-1, Klein Spring 2012 James Madison, Team 3-1, Klein Spring 2012 회원
JMU-KLEIN-S12S3G1
3 회원들
안내서 9개를 작성함
3가이드 댓글
Pretty accurate, nice guide! Easily repaired and it works!
Dominik Fryč - 답글
Where can I find the screen?
jackie fincher -
Perfect guide! But Where can i get original components??
Navin Singh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 17
전체 시간: 1,148
