주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Nokia Classic 2600c-2b Motherboard Replacement
필요한 것
  1. Nokia Classic 2600c-2b Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Nokia Classic 2600c-2b Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Nokia Classic 2600c-2b Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the back cover to expose the battery.
  3. Nokia Classic 2600c-2b Motherboard Replacement: 3 단계, 이미지 1/2 Nokia Classic 2600c-2b Motherboard Replacement: 3 단계, 이미지 2/2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
  4. Nokia Classic 2600c-2b Motherboard Replacement: 4 단계, 이미지 1/2 Nokia Classic 2600c-2b Motherboard Replacement: 4 단계, 이미지 2/2
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • Note: Some force is required
  5. Nokia Classic 2600c-2b Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the faceplate with the number pad attached.
  6. Nokia Classic 2600c-2b Motherboard Replacement: 6 단계, 이미지 1/1
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
  7. Nokia Classic 2600c-2b Motherboard Replacement: 7 단계, 이미지 1/2 Nokia Classic 2600c-2b Motherboard Replacement: 7 단계, 이미지 2/2
    • Locate the six screws positions along the edges of the motherboard.
    • Unscrew the six screws using the Torx 5 screwdriver (see Introduction for description of a Torx 5 screwdriver).
    • CAUTION! Place the screws in a secure location.
  8. Nokia Classic 2600c-2b Motherboard Replacement: 8 단계, 이미지 1/2 Nokia Classic 2600c-2b Motherboard Replacement: 8 단계, 이미지 2/2
    • Locate the orange ribbon tape connecting the metal display plate to the motherboard.
    • Lift the black latch attaching the tape to the motherboard.
    • Gently pull the tape out of the latch slot to remove the metal display.
  9. Nokia Classic 2600c-2b Motherboard Replacement: 9 단계, 이미지 1/2 Nokia Classic 2600c-2b Motherboard Replacement: 9 단계, 이미지 2/2
    • Using the plastic opening tool, gently pry off the motherboard from the plastic shell.
    • CAUTION! When pulling the motherboard out, be careful not to damage the battery under the lower left hand corner of the motherboard.
  10. Nokia Classic 2600c-2b Motherboard Replacement: 10 단계, 이미지 1/1
    • Turn the motherboard over and locate the orange ribbon tape connecting the display to the motherboard.
    • Gently pull the tape up to remove the display.
    • Replace the old motherboard with the new motherboard.
    • Follow the directions in reverse order to reassemble the phone.
결론
Ian VanZandt
회원 가입일: 02/14/12
654 평판
안내서 5개 작성하였습니다
James Madison, Team 3-1, Klein Spring 2012 James Madison, Team 3-1, Klein Spring 2012 회원
JMU-KLEIN-S12S3G1
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 632
