주요 콘텐츠로 건너뛰기
Nokia E61i Display Replacement
필요한 것
  1. Nokia E61i Display Replacement, Battery: 1 단계, 이미지 1/2 Nokia E61i Display Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Nokia E61i Display Replacement: 2 단계, 이미지 1/1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Display Replacement: 3 단계, 이미지 1/1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Display Replacement, Front Cover: 4 단계, 이미지 1/2 Nokia E61i Display Replacement, Front Cover: 4 단계, 이미지 2/2
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Display Replacement: 5 단계, 이미지 1/1
    • Remove the cover by pulling it up and off.
  6. Nokia E61i Display Replacement, Display: 6 단계, 이미지 1/2 Nokia E61i Display Replacement, Display: 6 단계, 이미지 2/2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon off of the contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Nokia E61i Display Replacement: 7 단계, 이미지 1/2 Nokia E61i Display Replacement: 7 단계, 이미지 2/2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Christopher Patton
회원 가입일: 04/07/11
208 평판
안내서 12개 작성하였습니다
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011 회원
CPSU-WALTERS-S11S9G63
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 9
전체 시간: 3,606
