이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the Nokia E61i screen.
필요한 것
Remove the back cover to access the battery. Press the tab on the bottom of the cover.
Slide the back cover downwards off of the phone while pressing the tab down.
Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
After casing and keyboard have been taken off, remove the screws holding the screen in place using a T-6 for the screws in the middle of the red circles and a T-5 for the screw in the middle of the red square.
Lift ribbon off of the contact with the logic board
*When reassembling, make sure to firmly press contacts into place to ensure a connection is made between ribbon and logic board
Once the screws are out, gently pull the screen off of the phone. *NOTICE* The sticker that attaches the display (in the middle of the blue square again) and the logic board is to be removed safely and be sure not to rip this apart.
Finally, pull the silver case off to completely free the cracked or damaged screen.
다른 3명이 해당 안내서를 완성하였습니다.
