메인 콘텐츠로 스킵하기
부품
지정된 부품이 없습니다.
  1. To start, press one of the latches at the top of the phone to open the rear cover.
    • To start, press one of the latches at the top of the phone to open the rear cover.
  2. Carefully press the other latch.
    • Carefully press the other latch.
  3. Open rear cover by this side.
    • Open rear cover by this side.
  4. Press the three latches to open this side of the cover.
    • Press the three latches to open this side of the cover.
  5. Remove the rear cover.
    • Remove the rear cover.
  6. Removed rear cover. See  the latches .
    • Removed rear cover. See the latches .
  7. Remove the screws using Torx T6 screw driver.
    • Remove the screws using Torx T6 screw driver.
  8. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  9. Remove six T6 screws.
    • Remove six T6 screws.
  10. Remove the assembly. The front cover will be released.
    • Remove the assembly. The front cover will be released.
  11. The front cover released.
    • The front cover released.
  12. To remove the display , unscrew the T6 Torx  at top.
    • To remove the display , unscrew the T6 Torx at top.
  13. CAUTION! Remove the bottom screw with T5 Torx screw driver, not T6 !
    • CAUTION! Remove the bottom screw with T5 Torx screw driver, not T6 !
  14. Carefully disconnect the Flex cable connector. Then remove the display.
    • Carefully disconnect the Flex cable connector. Then remove the display.
  15. Carefully remove the adhesive keyboard membrane.
    • Carefully remove the adhesive keyboard membrane.
    • You can replace it at this step if you need to.
  16. You can clean the keyboard surface with alcohol, if you dropped a drink here.
    • You can clean the keyboard surface with alcohol, if you dropped a drink here.
  17. When you replace the keyboard membrane,  align the two contacts at bottom.
    • When you replace the keyboard membrane, align the two contacts at bottom.
  18. You can wash the front cover and keyboard if they are dirty.
    • You can wash the front cover and keyboard if they are dirty.
  19. Keyboard - clean it if necessary.
    • Keyboard - clean it if necessary.
  20. Rear side of the circuit board.
    • Rear side of the circuit board.
  21. Speaker and antenna contacts.
    • Speaker and antenna contacts.
  22. If necessary, you can replace the joystick, the button module or the connector housing.
    • If necessary, you can replace the joystick, the button module or the connector housing.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jose Gustavo Abreu Murta
회원 가입일: 2010년 07월 06일
2,450 평판
안내서 7개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 7
전체 시간: 6,749
