주요 콘텐츠로 건너뛰기
Nokia E71x Camera Replacement
필요한 것
  1. Nokia E71x Camera Replacement, Motherboard: 1 단계, 이미지 1/2 Nokia E71x Camera Replacement, Motherboard: 1 단계, 이미지 2/2
    • Remove battery
  2. Nokia E71x Camera Replacement: 2 단계, 이미지 1/1
    • Using Torx number 4 unscrew the four 0.5mm screws.
  3. Nokia E71x Camera Replacement: 3 단계, 이미지 1/1
    • Push in four clips to detach the body.
  4. Nokia E71x Camera Replacement: 4 단계, 이미지 1/3 Nokia E71x Camera Replacement: 4 단계, 이미지 2/3 Nokia E71x Camera Replacement: 4 단계, 이미지 3/3
    • Separate the body into two pieces.
    • Be careful not to damage the screen or body. Some force will be needed to separate the body.
  5. Nokia E71x Camera Replacement: 5 단계, 이미지 1/3 Nokia E71x Camera Replacement: 5 단계, 이미지 2/3 Nokia E71x Camera Replacement: 5 단계, 이미지 3/3
    • Remove the bottom piece that is clipped on.
    • Some force will need to be exerted to remove the clip.
  6. Nokia E71x Camera Replacement: 6 단계, 이미지 1/1
    • Using Torx number 4 unscrew the two 0.7 mm screws at the top of the device.
  7. Nokia E71x Camera Replacement: 7 단계, 이미지 1/2 Nokia E71x Camera Replacement: 7 단계, 이미지 2/2
    • Once screws are removed detach back of phone from the motherboard.
    • This will require some force and maneuvering. Be careful not to break phone back or motherboard.
  8. Nokia E71x Camera Replacement: 8 단계, 이미지 1/1
    • Replace motherboard, ensure that replacement has the same serial number.
  9. Nokia E71x Camera Replacement, Camera: 9 단계, 이미지 1/2 Nokia E71x Camera Replacement, Camera: 9 단계, 이미지 2/2
    • Carefully un-clip camera ribbon. Install new camera.
    Product request on the Soldering iron
    lineberryjames6 - 답글
결론
다른 3명이 해당 안내서를 완성하였습니다.
Will Goldby
회원 가입일: 08/29/11
187 평판
안내서 4개 작성하였습니다
Cuesta, Team 1-1, Zipperian Fall 2011 Cuesta, Team 1-1, Zipperian Fall 2011 회원
CUESTA-ZIPPERIAN-F11S1G1
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Will a Nokia E72 replacement camera part work in the Nokia E71 motherboard? In other words, can one upgrade the Nokia E71’s 3.2 MP camera to 5.0 MP using a spare part made for an E72?
Gam - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,444
