주요 콘텐츠로 건너뛰기
Nokia E90 Inside Screen Replacement
필요한 것
  1. Nokia E90 Inside Screen Replacement, Front Cover: 1 단계, 이미지 1/1
    • Start with the phone in the flipped open position.
    • You must remove the sticker in the center, below the screen to reveal the center screw.
    • Use a T5 screwdriver to remove all three screws, loosening the front screen.
  2. Nokia E90 Inside Screen Replacement: 2 단계, 이미지 1/2 Nokia E90 Inside Screen Replacement: 2 단계, 이미지 2/2
    • Flip the phone to the closed position and turn to the front screen.
    • The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
  3. Nokia E90 Inside Screen Replacement, Front Screen and Front Keypad: 3 단계, 이미지 1/1
    • With the front cover off, the screen and keypad should be loose.
  4. Nokia E90 Inside Screen Replacement: 4 단계, 이미지 1/2 Nokia E90 Inside Screen Replacement: 4 단계, 이미지 2/2
    • Using a plastic opening tool pry up the cable connecting the LCD screen to the rest of the phone.
    • With the cable disconnected, the screen should be free for removal or replacement.
  5. Nokia E90 Inside Screen Replacement, Inside Screen: 5 단계, 이미지 1/1
    • After removing the front screen and front keypad, your device should look like this.
  6. Nokia E90 Inside Screen Replacement: 6 단계, 이미지 1/3 Nokia E90 Inside Screen Replacement: 6 단계, 이미지 2/3 Nokia E90 Inside Screen Replacement: 6 단계, 이미지 3/3
    • Using the T5 Screwdriver, remove the two screws shown.
  7. Nokia E90 Inside Screen Replacement: 7 단계, 이미지 1/1
    • Make sure to remove the connection shown by gently easing the plastic opening tool underneath the connection and lightly prying the connection apart.
  8. Nokia E90 Inside Screen Replacement: 8 단계, 이미지 1/2 Nokia E90 Inside Screen Replacement: 8 단계, 이미지 2/2
    • Gently, lift the board up to reveal the front screen.
  9. Nokia E90 Inside Screen Replacement: 9 단계, 이미지 1/3 Nokia E90 Inside Screen Replacement: 9 단계, 이미지 2/3 Nokia E90 Inside Screen Replacement: 9 단계, 이미지 3/3
    • Using the plastic opening tool, lift and remove the inside screen.
결론
In order to install a new screen, simply follow the steps in reverse order with the new screen.
다른 4명이 해당 안내서를 완성하였습니다.
Cameron Weinberg
회원 가입일: 04/12/11
540 평판
안내서 6개 작성하였습니다
Cal Poly, Team 18-21, Garner Spring 2011 Cal Poly, Team 18-21, Garner Spring 2011 회원
CPSU-GARNER-S11S18G21
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 11
전체 시간: 5,301
