주요 콘텐츠로 건너뛰기
Nokia E90 QWERTY Keyboard Replacement
필요한 것
  1. Nokia E90 QWERTY Keyboard Replacement, Battery Cover and Battery: 1 단계, 이미지 1/1
    • In order to remove the back cover, you must press the indicated button.
  2. Nokia E90 QWERTY Keyboard Replacement: 2 단계, 이미지 1/2 Nokia E90 QWERTY Keyboard Replacement: 2 단계, 이미지 2/2
    • With the button pressed, apply light pressure and slide the back cover off.
    • This will allow you to access the battery
  3. Nokia E90 QWERTY Keyboard Replacement: 3 단계, 이미지 1/1
    • In order to remove the battery, pull it out from the same side that the rubber button is on.
  4. Nokia E90 QWERTY Keyboard Replacement, Back Cover: 4 단계, 이미지 1/3 Nokia E90 QWERTY Keyboard Replacement, Back Cover: 4 단계, 이미지 2/3 Nokia E90 QWERTY Keyboard Replacement, Back Cover: 4 단계, 이미지 3/3
    • Using a plastic opening tool, separate the back cover from the phone.
  5. Nokia E90 QWERTY Keyboard Replacement: 5 단계, 이미지 1/2 Nokia E90 QWERTY Keyboard Replacement: 5 단계, 이미지 2/2
    • Continue along the edge with the plastic opening tool.
  6. Nokia E90 QWERTY Keyboard Replacement: 6 단계, 이미지 1/3 Nokia E90 QWERTY Keyboard Replacement: 6 단계, 이미지 2/3 Nokia E90 QWERTY Keyboard Replacement: 6 단계, 이미지 3/3
    • Gently, remove the back cover.
  7. Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: 7 단계, 이미지 1/3 Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: 7 단계, 이미지 2/3 Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: 7 단계, 이미지 3/3
    • Unscrew the indicated screws using the T5 screwdriver.
  8. Nokia E90 QWERTY Keyboard Replacement: 8 단계, 이미지 1/2 Nokia E90 QWERTY Keyboard Replacement: 8 단계, 이미지 2/2
    • Open the phone up and use the plastic opening tool to remove the cover to the keyboard.
    • Be careful not to break the plastic during this step; do your best not to force anything.
  9. Nokia E90 QWERTY Keyboard Replacement: 9 단계, 이미지 1/2 Nokia E90 QWERTY Keyboard Replacement: 9 단계, 이미지 2/2
    • The button board will be loose once the cover is removed.
    • Lift it up to reveal the sensor board.
  10. Nokia E90 QWERTY Keyboard Replacement: 10 단계, 이미지 1/2 Nokia E90 QWERTY Keyboard Replacement: 10 단계, 이미지 2/2
    • With the T5 Screwdriver, remove the marked screws.
  11. Nokia E90 QWERTY Keyboard Replacement: 11 단계, 이미지 1/2 Nokia E90 QWERTY Keyboard Replacement: 11 단계, 이미지 2/2
    • With the screws removed, the sensor board should be free to flip up.
  12. Nokia E90 QWERTY Keyboard Replacement: 12 단계, 이미지 1/2 Nokia E90 QWERTY Keyboard Replacement: 12 단계, 이미지 2/2
    • Disconnect the wire with the plastic opening tool.
  13. Nokia E90 QWERTY Keyboard Replacement: 13 단계, 이미지 1/3 Nokia E90 QWERTY Keyboard Replacement: 13 단계, 이미지 2/3 Nokia E90 QWERTY Keyboard Replacement: 13 단계, 이미지 3/3
    • Remove the screws marked.
    • The Screw on the left is located underneath the cable.
    • With those screws removed, the circuit board and sensor board will be detached from the rest of the phone.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Cameron Weinberg
회원 가입일: 04/12/11
540 평판
안내서 6개 작성하였습니다
Cal Poly, Team 18-21, Garner Spring 2011 Cal Poly, Team 18-21, Garner Spring 2011 회원
CPSU-GARNER-S11S18G21
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 6,363
