소개
Use this guide to replace the back cover of your Nokia G42 5G.
필요한 것
Power down your phone and unplug any cables.
Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the upper left edge of the phone.
Press firmly to eject the tray.
Insert an opening pick under the small notch in the SIM card tray slot.
Position the opening pick at a steep downward angle between the back cover and the screen assembly.
Slide the opening pick down the left edge of the phone to release the plastic clips.
With the phone laying screen-side down, carefully lift the right edge of the back cover, opening it like a book.
Lay the back cover next to the phone.
Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the fingerprint reader bracket.
Use a pair of tweezers or your fingers to remove the fingerprint reader bracket.
Use the pointed end of a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
Remove the back cover.
Using a pair of tweezers, grip the top of the fingerprint reader and lift it out and around the top plastic tab, separating it from the back cover.
Use a pair of tweezers to lift the fingerprint reader out of its bottom plastic tab.
Remove the fingerprint reader.
댓글 한 개
Very simple and to the point! Worked like a charm. The only qualm I have is that the replacement did not have camera lens covers. They had little blue plastic circles over them but once you bring those up, there’s nothing underneath.
I ordered this to replace the back on my G310 5G and it does fit!
