주요 콘텐츠로 건너뛰기
Nokia Lumia 1020 Screen Replacement
필요한 것
  1. Nokia Lumia 1020 Screen Replacement, Screen: 1 단계, 이미지 1/2 Nokia Lumia 1020 Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Use a SIM door key to remove the SIM card and SIM card tray from the device.
    • Use a T4 screwdriver to loosen the captured torx screw to the right of the SIM card tray (the screw will not come out).
  2. Nokia Lumia 1020 Screen Replacement: 2 단계, 이미지 1/3 Nokia Lumia 1020 Screen Replacement: 2 단계, 이미지 2/3 Nokia Lumia 1020 Screen Replacement: 2 단계, 이미지 3/3
    • Wedge a spudger in between the screen and the back of the device, starting from the top left corner of the phone.
    • Gently pry the screen away from the back of the device using slight upward pressure.
    • Slide the spudger down towards the bottom left corner of the device, continuing to gently pry upwards. The screen will now be slightly separated from the back of the phone.
  3. Nokia Lumia 1020 Screen Replacement: 3 단계, 이미지 1/3 Nokia Lumia 1020 Screen Replacement: 3 단계, 이미지 2/3 Nokia Lumia 1020 Screen Replacement: 3 단계, 이미지 3/3
    • Wedge a spudger underneath the silver rectangle in the upper right corner until it pops off the back of the phone.
  4. Nokia Lumia 1020 Screen Replacement: 4 단계, 이미지 1/3 Nokia Lumia 1020 Screen Replacement: 4 단계, 이미지 2/3 Nokia Lumia 1020 Screen Replacement: 4 단계, 이미지 3/3
    • Wedge a spudger underneath the silver rectangle in the lower left corner until it pops off the back of the phone.
    • Completely remove the screen from the back of the phone.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Sydney Hostelley
회원 가입일: 02/15/18
614 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G4, Leahy Spring 2018 USF Tampa, Team S1-G4, Leahy Spring 2018 회원
USFT-LEAHY-S18S1G4
4 회원들
안내서 10개 작성하였습니다
댓글 3개
Topo très utile. Merci.
Il serait bien de préciser que, après avoir déposé l'écran, il faut encore transférer la caméra de l'ancien au nouvel écran.
JPKuypers - 답글
Topo bien clair. Merci.
Il serait bien de préciser que, après avoir déposé l'écran, il faut encore transférer la caméra de l'ancien écran vers le nouvel écran.
JPKuypers - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 29
전체 시간: 2,133
