소개
This guide will describe how to remove the speaker of your Nokia Lumia 1020.
This replacement will be useful if you want to replace a damaged speaker. Speakers can be damaged from broken wires or water damage. If the speaker sound quality is significantly decreased, you may want to consider replacing your speaker.
필요한 것
Use a SIM door key to remove the SIM card and SIM card tray from the device.
Use a T4 screwdriver to loosen the captured torx screw to the right of the SIM card tray (the screw will not come out).
Wedge a spudger in between the screen and the back of the device, starting from the top left corner of the phone.
Gently pry the screen away from the back of the device using slight upward pressure.
Slide the spudger down towards the bottom left corner of the device, continuing to gently pry upwards. The screen will now be slightly separated from the back of the phone.
Unscrew the two 4 mm torx screws on the top silver strip with a T4 screwdriver.
Unscrew the 4.5 mm torx screw above the gold bar with a T6 screwdriver.
Grab the edges of the gold strip with gripped tweezers to remove. The gold and silver metal will come off together.
Use the T4 screwdriver to remove the 4 mm torx screw.
Remove the headphone jack by pulling back on the silver plate with your fingernail.
Use your fingernail to grip the rear-facing camera on the upper middle part of the back of the phone. Pry until it pops off to the left.
Remove the camera by wedging a spudger underneath the attached gold foil.
Use a hairdryer to heat up the adhesive of the plastic base. This may take around 5 minutes.
Now that the charging port and speaker components have been removed, separate the two components in order to retrieve the speaker.
Wedge the spudger between the charging port and speaker components and push outwards.
After disassembling the components, the speaker can now be retrieved. This part is highlighted in red.
