1. Apply heat pad to each side of the device.
    • Apply heat pad to each side of the device.
    • When using any heat pad please use some form of padded gloves so you don't burn you fingers.
    • Microwave the pad for 30 seconds so an ample amount of heat is given on all four sides. Do not microwave more than once every two minutes.
  2. Insert the pick between the glass to separate the glass from the device. You can also use the suction cups to help lift the glass. When pulling the screen off the chassis be careful not to cut  the ribbon cable the connect the screen to the logic board. Take your time to pry open the screen from the chassis. In this process you can easily break the screen or crack it.
    • Insert the pick between the glass to separate the glass from the device. You can also use the suction cups to help lift the glass.
    • When pulling the screen off the chassis be careful not to cut the ribbon cable the connect the screen to the logic board.
    • Take your time to pry open the screen from the chassis. In this process you can easily break the screen or crack it.
  3. Pull out the ribbon cable from its connection Once that done move on to remove the ribbon connection from the screen.
    • Pull out the ribbon cable from its connection
    • Once that done move on to remove the ribbon connection from the screen.
  4. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Use the plastic pry tool to remove one of the connection. Use the plastic pry tool to remove one of the connection. Use the plastic pry tool to remove one of the connection.
    • Use the plastic pry tool to remove one of the connection.
  6. Once down everything is completed.
    • Once down everything is completed.
  7. Before removing the battery from the device be sure not to puncture the battery. Since the battery is a form of acid. Using a plastic pry tool is better than a metal tool when working with wire and soft case battery case. Use a plastic pry tool to remove the battery connector from the logic board.
    • Before removing the battery from the device be sure not to puncture the battery. Since the battery is a form of acid.
    • Using a plastic pry tool is better than a metal tool when working with wire and soft case battery case.
    • Use a plastic pry tool to remove the battery connector from the logic board.
  8. Remove the ribbon located over the battery. Remove the ribbon located over the battery.
    • Remove the ribbon located over the battery.
  9. Theres four screws that attach the battery to the chassis. Use a PH0 Phillips head screwdriver to loosen the screw.
    • Theres four screws that attach the battery to the chassis. Use a PH0 Phillips head screwdriver to loosen the screw.
    • Since the tool using is sharp please use with caution, so that you don't puncture the battery.
  10. Take a plastic pry to to pry out the battery from its casing. The bottom of the battery has adhesive to hold the battery in place. So using enough pressure to pry the battery is ok . Using two tool different plastic pry to can help give you leverage on areas that are hard to get up.
    • Take a plastic pry to to pry out the battery from its casing.
    • The bottom of the battery has adhesive to hold the battery in place. So using enough pressure to pry the battery is ok .
    • Using two tool different plastic pry to can help give you leverage on areas that are hard to get up.
결론
Degan Berhe
회원 가입일: 2018년 08월 29일
473 평판
안내서 4개 작성하였습니다
Gateway, Team S1-G4, Luster Fall 2018 Gateway, Team S1-G4, Luster Fall 2018 회원
GCC-LUSTER-F18S1G4
5 회원들
안내서 5개 작성하였습니다
조회 통계:
지난 24시간: 4
지난 7일: 22
지난 30일: 77
전체 시간: 232
