주요 콘텐츠로 건너뛰기
소개
Battery draining quickly? It may be time for a new one. Use this guide to help you replace your phone's battery.
도구
부품
지정된 부품이 없습니다.
  1. Insert the spudger into the crevice located between the back cover of the phone and the body of the phone. Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
    • Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
  2. Lift the spudger gently to open the back cover of the phone. Lift the spudger gently to open the back cover of the phone.
    • Lift the spudger gently to open the back cover of the phone.
  3. Insert the spudger into the space between the batter and the battery holder to remove the battery. Insert the spudger into the space between the batter and the battery holder to remove the battery.
    • Insert the spudger into the space between the batter and the battery holder to remove the battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kobina Faibille
회원 가입일: 2015년 11월 03일
156 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 UMass Dartmouth, Team 1-5, Bhusal Fall 2015 회원
UMASSD-BHUSAL-F15S1G5
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
First off you don t need any tools to open this device, secondly you may damage the sim board in section 2 of this tutorial.There is a ) at the bottom of thephone to easily remove the battery.Use your fingers to gently push open the cover at the corners of the phone changing battery takes 1 minte.
beerwings1776 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 3,088
