주요 콘텐츠로 건너뛰기
Nokia Lumia 520 Battery Replacement
필요한 것
  1. Nokia Lumia 520 Battery Replacement, Battery: 1 단계, 이미지 1/2 Nokia Lumia 520 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
  2. Nokia Lumia 520 Battery Replacement: 2 단계, 이미지 1/2 Nokia Lumia 520 Battery Replacement: 2 단계, 이미지 2/2
    • Lift the spudger gently to open the back cover of the phone.
    Plastic guitar pick worked really well for me. Easy to insert and slide around to unlatch case.
    anluan - 답글
  3. Nokia Lumia 520 Battery Replacement: 3 단계, 이미지 1/2 Nokia Lumia 520 Battery Replacement: 3 단계, 이미지 2/2
    • Insert the spudger into the space between the batter and the battery holder to remove the battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kobina Faibille
회원 가입일: 11/03/15
156 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 UMass Dartmouth, Team 1-5, Bhusal Fall 2015 회원
UMASSD-BHUSAL-F15S1G5
3 회원들
안내서 8개 작성하였습니다
댓글 2개
First off you don t need any tools to open this device, secondly you may damage the sim board in section 2 of this tutorial.There is a ) at the bottom of thephone to easily remove the battery.Use your fingers to gently push open the cover at the corners of the phone changing battery takes 1 minte.
beerwings1776 - 답글
Greetings I have a Lumia & I need the Screen and Battery,so how can I get those 2?
Ayoba - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 21
전체 시간: 3,636
