주요 콘텐츠로 건너뛰기
Nokia Lumia 520 Power/Volume Switch Replacement
필요한 것
  1. Nokia Lumia 520 Power/Volume Switch Replacement, Battery: 1 단계, 이미지 1/2 Nokia Lumia 520 Power/Volume Switch Replacement, Battery: 1 단계, 이미지 2/2
    • Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
  2. Nokia Lumia 520 Power/Volume Switch Replacement: 2 단계, 이미지 1/2 Nokia Lumia 520 Power/Volume Switch Replacement: 2 단계, 이미지 2/2
    • Lift the spudger gently to open the back cover of the phone.
  3. Nokia Lumia 520 Power/Volume Switch Replacement: 3 단계, 이미지 1/2 Nokia Lumia 520 Power/Volume Switch Replacement: 3 단계, 이미지 2/2
    • Insert the spudger into the space between the batter and the battery holder to remove the battery.
  4. Nokia Lumia 520 Power/Volume Switch Replacement, Power/Volume Switch: 4 단계, 이미지 1/3 Nokia Lumia 520 Power/Volume Switch Replacement, Power/Volume Switch: 4 단계, 이미지 2/3 Nokia Lumia 520 Power/Volume Switch Replacement, Power/Volume Switch: 4 단계, 이미지 3/3
    • Unscrew the 8 screws with a Torx screw driver (T4). After all screws are unscrewed place them next to the phone in the order
  5. Nokia Lumia 520 Power/Volume Switch Replacement: 5 단계, 이미지 1/2 Nokia Lumia 520 Power/Volume Switch Replacement: 5 단계, 이미지 2/2
    • Use your spudger to remove the plastic casing over the motherboard. Do it very slowly because it will be tough to remove and you do not want to break it.
  6. Nokia Lumia 520 Power/Volume Switch Replacement: 6 단계, 이미지 1/2 Nokia Lumia 520 Power/Volume Switch Replacement: 6 단계, 이미지 2/2
    • Carefully unclip the digitizer touch screen cable and the display screen cable using a spudger.
  7. Nokia Lumia 520 Power/Volume Switch Replacement: 7 단계, 이미지 1/2 Nokia Lumia 520 Power/Volume Switch Replacement: 7 단계, 이미지 2/2
    • Gently remove the motherboard with your hands.
    • Flip it over and turn it 90 degrees to the left so the buttons are in front of you.
    • You will see four small switches close to the side of the circuit board.
  8. Nokia Lumia 520 Power/Volume Switch Replacement: 8 단계, 이미지 1/1
    • Gently take the power/volume switches off using a pair of needle nose pliers. Gently clean the solder that was there. Replace the solder with a new coat of solder.
    • Check out iFixit's soldering guides, here.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Eduardo Perez
회원 가입일: 11/03/15
189 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 UMass Dartmouth, Team 1-5, Bhusal Fall 2015 회원
UMASSD-BHUSAL-F15S1G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 5,533
