주요 콘텐츠로 건너뛰기
Nokia Lumia 520 and 521 Touch Window Replacement
필요한 것
  1. Nokia Lumia 520 and 521 Touch Window Replacement, Touch Window: 1 단계, 이미지 1/3 Nokia Lumia 520 and 521 Touch Window Replacement, Touch Window: 1 단계, 이미지 2/3 Nokia Lumia 520 and 521 Touch Window Replacement, Touch Window: 1 단계, 이미지 3/3
    • The damage to the digitizer is clearly visible. Nokia refers to the glass/digitizer combo as the "touch window"
    • Turn the phone over,
    • and release the back cover by pushing it off the phone from the top
  2. Nokia Lumia 520 and 521 Touch Window Replacement: 2 단계, 이미지 1/3 Nokia Lumia 520 and 521 Touch Window Replacement: 2 단계, 이미지 2/3 Nokia Lumia 520 and 521 Touch Window Replacement: 2 단계, 이미지 3/3
    • With the back cover removed, the battery becomes visible.
    • Lift up the battery from the bottom and remove it.
    • Unscrew the five Torx+4 screws.
  3. Nokia Lumia 520 and 521 Touch Window Replacement: 3 단계, 이미지 1/3 Nokia Lumia 520 and 521 Touch Window Replacement: 3 단계, 이미지 2/3 Nokia Lumia 520 and 521 Touch Window Replacement: 3 단계, 이미지 3/3
    • These five screws are 5mm in length
    • Next remove the three Torx+4 screws
    • Those screws are machine screws M1.5x3
    • The Nokia 521 has a 4th screw in the lower left corner of the battery compartment.
  4. Nokia Lumia 520 and 521 Touch Window Replacement: 4 단계, 이미지 1/3 Nokia Lumia 520 and 521 Touch Window Replacement: 4 단계, 이미지 2/3 Nokia Lumia 520 and 521 Touch Window Replacement: 4 단계, 이미지 3/3
    • Release the two clips on the bottom of the phone by using a guitar pick or similar opening tool
    • Simply insert the tool in the gap between the case halves and slightly rotate the tool to free the clips.
    • Continue to work the tool all the way round.
  5. Nokia Lumia 520 and 521 Touch Window Replacement: 5 단계, 이미지 1/3 Nokia Lumia 520 and 521 Touch Window Replacement: 5 단계, 이미지 2/3 Nokia Lumia 520 and 521 Touch Window Replacement: 5 단계, 이미지 3/3
    • The last clip should be on the top of the phone.
    • Once those are released, the case will simply open up. With the cover (Nokia calls it the D-cover) removed, the logic board will be visible.
  6. Nokia Lumia 520 and 521 Touch Window Replacement: 6 단계, 이미지 1/3 Nokia Lumia 520 and 521 Touch Window Replacement: 6 단계, 이미지 2/3 Nokia Lumia 520 and 521 Touch Window Replacement: 6 단계, 이미지 3/3
    • Remove the digitizer flex cable by using an opening tool, or spudger, from the connector
    • Here is the flex cable removed from the connector
    • Next remove the display flex with an opening tool, or spudger, from the connector.
  7. Nokia Lumia 520 and 521 Touch Window Replacement: 7 단계, 이미지 1/3 Nokia Lumia 520 and 521 Touch Window Replacement: 7 단계, 이미지 2/3 Nokia Lumia 520 and 521 Touch Window Replacement: 7 단계, 이미지 3/3
    • Display flex removed from the connector
    • Use an opening tool, or a spudger, to remove the logic board from the case. It is simply held in by two clips.
    • Remove the logic board from the front assembly
  8. Nokia Lumia 520 and 521 Touch Window Replacement: 8 단계, 이미지 1/2 Nokia Lumia 520 and 521 Touch Window Replacement: 8 단계, 이미지 2/2
    • Use a guitar pick or similar opening tool to unsnap the touch window assembly from the support frame.
    • This will separate the touch window from the rest of the phone.
결론
다른 101명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
781,057 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
32 회원들
안내서 530개 작성하였습니다
댓글 20개
I used a t5 screwdriver and it worked perfectly :D
tnx for the guide!!
ivan coene - 답글
Probably one of the easiest repairs i have ever done, tip pay, an extra few pounds and get the digitizer with the frame.
adrian lunn - 답글
Hi Adrian, where did you buy the Touch Windows? I asked Nokia but they do not sell it..
Thanks.
Rod
Rodolfo Antola -
The last and hardest step is missing---separating the digitizer from the surround. They are glued together and you basically have to destroy the glass to get it off. (See the teardown for details.) Other than that, a great guide, thanks.
joe - 답글
Well... you're trying to replace the glass in the first place, so it's technically already destroyed.
Also, I broke my Lumia 520 screen and I'm waiting for the replacement screen to arrive. If you use your thumbnail or something very thin but strong, you can separate the glass from the frame without causing more damage to the glass by running it underneath the edges of the glass, all the way around.
Granted, it took a couple of goes to separate them because of the glue, but it did come off without breaking either the frame or the glass.
Choi Nxiella -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 21
전체 시간: 140,468
