주요 콘텐츠로 건너뛰기
Nokia Lumia 521 Headphone Jack Replacement
필요한 것
  1. Nokia Lumia 521 Headphone Jack Replacement, Battery: 1 단계, 이미지 1/2 Nokia Lumia 521 Headphone Jack Replacement, Battery: 1 단계, 이미지 2/2
    • Push the plastic opening tool in between the screen and the back case of the phone.
    • Pry the top of the phone between the case and screen until they are separated.
  2. Nokia Lumia 521 Headphone Jack Replacement: 2 단계, 이미지 1/1
    • Once the cover has been removed, the battery will be visible. Grab the plastic tab and pull it to remove the battery from its place. If there is no plastic tab, use the plastic opening tool to pry the battery loose.
  3. Nokia Lumia 521 Headphone Jack Replacement, SIM Card: 3 단계, 이미지 1/1
    • After the battery is removed, push the SIM card from the left side with your thumb until it is loose.
  4. Nokia Lumia 521 Headphone Jack Replacement, Motherboard: 4 단계, 이미지 1/2 Nokia Lumia 521 Headphone Jack Replacement, Motherboard: 4 단계, 이미지 2/2
    • Using the Torx T5 screw head, remove all screws. Note that there are two different sized screws. Five screws are 5 mm long and four are 4 mm long.
    • Five 5 mm screws.
    • Four 4 mm screws.
  5. Nokia Lumia 521 Headphone Jack Replacement: 5 단계, 이미지 1/2 Nokia Lumia 521 Headphone Jack Replacement: 5 단계, 이미지 2/2
    • Using a plastic opening tool, pry apart the inner back case apart from the rest of the phone, starting at the top and prying while going around the phone.
  6. Nokia Lumia 521 Headphone Jack Replacement: 6 단계, 이미지 1/2 Nokia Lumia 521 Headphone Jack Replacement: 6 단계, 이미지 2/2
    • Unclasp the motherboard from the black case clasps using a plastic opening tool.
  7. Nokia Lumia 521 Headphone Jack Replacement: 7 단계, 이미지 1/2 Nokia Lumia 521 Headphone Jack Replacement: 7 단계, 이미지 2/2
    • Unclip the motherboard clasps using your fingers or a plastic opening tool.
  8. Nokia Lumia 521 Headphone Jack Replacement, Headphone Jack: 8 단계, 이미지 1/2 Nokia Lumia 521 Headphone Jack Replacement, Headphone Jack: 8 단계, 이미지 2/2
    • Gently pry audio jack with your hand until it is removed from its space on the phone.
  9. Nokia Lumia 521 Headphone Jack Replacement: 9 단계, 이미지 1/1
    • Unclasp the golden flap attached to the audio jack using the plastic opening tool (The top golden flap should already be unclasped from removing the motherboard).
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Destiny Jenkins
회원 가입일: 02/10/16
388 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-4, Sullivan Spring 2016 USF Tampa, Team 2-4, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 329
