주요 콘텐츠로 건너뛰기
Nokia Lumia 521 SIM Card Replacement
필요한 것
  1. Nokia Lumia 521 SIM Card Replacement, Battery: 1 단계, 이미지 1/2 Nokia Lumia 521 SIM Card Replacement, Battery: 1 단계, 이미지 2/2
    • Push the plastic opening tool in between the screen and the back case of the phone.
    • Pry the top of the phone between the case and screen until they are separated.
  2. Nokia Lumia 521 SIM Card Replacement: 2 단계, 이미지 1/1
    • Once the cover has been removed, the battery will be visible. Grab the plastic tab and pull it to remove the battery from its place. If there is no plastic tab, use the plastic opening tool to pry the battery loose.
  3. Nokia Lumia 521 SIM Card Replacement, SIM Card: 3 단계, 이미지 1/1
    • After the battery is removed, push the SIM card from the left side with your thumb until it is loose.
결론
Marko Stanisic
회원 가입일: 02/10/16
322 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-4, Sullivan Spring 2016 USF Tampa, Team 2-4, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 1,516
