주요 콘텐츠로 건너뛰기
Nokia Lumia 530 Touch screen, LCD Display Replacement
필요한 것
동영상 개요
  1. Nokia Lumia 530 Touch screen, LCD Display Replacement, Loudspeaker and Earpiece: 1 단계, 이미지 1/3 Nokia Lumia 530 Touch screen, LCD Display Replacement, Loudspeaker and Earpiece: 1 단계, 이미지 2/3 Nokia Lumia 530 Touch screen, LCD Display Replacement, Loudspeaker and Earpiece: 1 단계, 이미지 3/3
    • Turn off the phone.
    • Remove the battery and any installed SIM and memory cards. There are two tapes screws:
    • 4x Torx T6
    • 5x Torx T5
    • Remove the middle bezel.
    • Earpiece
    • Earpiece Flex Cable
    • Loudspeaker / Ringer
  2. Nokia Lumia 530 Touch screen, LCD Display Replacement, Logic Board: 2 단계, 이미지 1/3 Nokia Lumia 530 Touch screen, LCD Display Replacement, Logic Board: 2 단계, 이미지 2/3 Nokia Lumia 530 Touch screen, LCD Display Replacement, Logic Board: 2 단계, 이미지 3/3
    • Disconnect the touch screen & display flex cable.
    • Remove the main board.
  3. Nokia Lumia 530 Touch screen, LCD Display Replacement, Touch screen or LCD Display Replacement: 3 단계, 이미지 1/3 Nokia Lumia 530 Touch screen, LCD Display Replacement, Touch screen or LCD Display Replacement: 3 단계, 이미지 2/3 Nokia Lumia 530 Touch screen, LCD Display Replacement, Touch screen or LCD Display Replacement: 3 단계, 이미지 3/3
    • If the glass is broken, put some scotch tape to prevent it breake to pieces.
    • Use a hot air to make adhesive tape more soften.
    • For this operation you can use a hairdryer.
    • Use a cutter and make small room to insert a plastic pick.
  4. Nokia Lumia 530 Touch screen, LCD Display Replacement: 4 단계, 이미지 1/3 Nokia Lumia 530 Touch screen, LCD Display Replacement: 4 단계, 이미지 2/3 Nokia Lumia 530 Touch screen, LCD Display Replacement: 4 단계, 이미지 3/3
    • Continue with the separation by using a plastic tools.
    • If necessary, use the hot air again
  5. Nokia Lumia 530 Touch screen, LCD Display Replacement: 5 단계, 이미지 1/2 Nokia Lumia 530 Touch screen, LCD Display Replacement: 5 단계, 이미지 2/2
    • Unstuck the Touch screen flex cable from the display.
    • If you have a broken glass, you can cut the touch screen flex cable, otherwise unsolder it careful like in the next step.
  6. Nokia Lumia 530 Touch screen, LCD Display Replacement: 6 단계, 이미지 1/3 Nokia Lumia 530 Touch screen, LCD Display Replacement: 6 단계, 이미지 2/3 Nokia Lumia 530 Touch screen, LCD Display Replacement: 6 단계, 이미지 3/3
    • The display edges are glued to the glass with adhesive tape.
    • Use only thin plastic tools for the separation.
  7. Nokia Lumia 530 Touch screen, LCD Display Replacement: 7 단계, 이미지 1/3 Nokia Lumia 530 Touch screen, LCD Display Replacement: 7 단계, 이미지 2/3 Nokia Lumia 530 Touch screen, LCD Display Replacement: 7 단계, 이미지 3/3
    • Remove the blue sticker.
    • With a soldering iron, remove the touch screen flex cable and install the new one.
    • Put back the blue sticker.
  8. Nokia Lumia 530 Touch screen, LCD Display Replacement: 8 단계, 이미지 1/3 Nokia Lumia 530 Touch screen, LCD Display Replacement: 8 단계, 이미지 2/3 Nokia Lumia 530 Touch screen, LCD Display Replacement: 8 단계, 이미지 3/3
    • If the spare part is without tape, install a new one.
    • Carefully put the display in place, then install the glass.
    • Start with reassembling.
  9. Nokia Lumia 530 Touch screen, LCD Display Replacement: 9 단계, 이미지 1/1
    • That's all.
    • Did you do it successfully?
결론
다른 15명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,278 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 10개
What did you apply in the first frame of step 7? 4:15 in the video.
Paul Reich - 답글
soldering flux
ZFix -
Thanks for confirming
Paul Reich -
I didn't end up doing it correctly - it didn't work.
I think the mistake I made was not heating the old flex cable off the connector. I didn't follow instructions correctly and I pulled it off. I was able to heat the leftover connectors off but after soldering the new flex onto the board and sealing up it didnt work - screen still unresponsive :-(
It was my first attempt at replacing a screen (and I don't have any experience) so I'm not too bummed.
I just ordered a complete LCD and digitizer instead :-)
Paul Reich - 답글
Failed miserably... Soldering iron not adapted. Might want to emphasise that is critical. At least I tried...
ricochapuis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 37,158
