주요 콘텐츠로 건너뛰기
Nokia Lumia 635, 630 - Hard Reset
동영상 개요
  1. Nokia Lumia 635, 630 - Hard Reset, Nokia Lumia 635, 630 - Hard Reset: 1 단계, 이미지 1/3 Nokia Lumia 635, 630 - Hard Reset, Nokia Lumia 635, 630 - Hard Reset: 1 단계, 이미지 2/3 Nokia Lumia 635, 630 - Hard Reset, Nokia Lumia 635, 630 - Hard Reset: 1 단계, 이미지 3/3
    • Turn the phone off.
    • Press and hold the power button. When the phone vibrates, release it and press and hold the volume down button until you see the exclamation mark on the screen.
    • Another way to do this - press and hold the volume down button and connect the charger.
    • Whit the exclamation mark on the screen press this sequence of keys:
    • -> Volume Up
    • -> Volume Down
    • -> Power button
    • -> Volume Down
    Mine won't go to ! It keeps rebooting to Nokia
    Trillix Wolfie - 답글
    My phone ignores the sequence. It was set up as a child phone, and there’s no “reset phone” button in the about menu. It in fact doesn’t even have the about menu. And trying to reset it using buttons, I get exclamation mark, and once I push the Volume Up button, it starts to boot normally and ignores the rest.
    Sergey Kofanov - 답글
    THanks its a useful ways it works on my phone…nice one
    Abasi Kadewele - 답글
    thank you it worked on my phone!!! I’m very glad! Thank you again!
    szabo_istvan78 - 답글
    When I turn on my Lumia 635, it displays "Nokia" and goes off then comes on again and only display Nokia. After resetting it, it continues the same
    Frank Inyiama - 답글
    my lumia phone was switch off showing Nokia sign in every 10 seconds. after hard reset , it is showing charging sign. what to do next .
    flora - 답글
    Thank you, it worked on my phone. I’m very happy now
    Arham Jahangir - 답글
    Works perfectly,
    thanks.
    And just a note for everyone, TAKE YOUR SD CARD OUT FIRST!!!!! IT WILL WIPE THE DATA!!!!
    Austin Wilson - 답글
    Worked perfectly thank you for this info!!
    jessiecrego83 - 답글
    non riesco a resettare il mio lumia, sarà perchè il sistema operativo è stato aggiornato con il 10?
    qualcuno può suggerirmi qualcosa?
    rosario marchica - 답글
결론
다른 63명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,308 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 32개
Hey, I have done it on the computer, reload the windows but still I get the exclamanition, also the battery is death right now and I don't know how its gonna charge?
remzicanakile - 답글
Phone get rain water, I want to mention it.It opens dont problenm but that sign (!) gonna drive me mad!!
remzicanakile - 답글
Will this delete contact numbers
suryansh - 답글
Yes if you have the numbers stored somewhere not on the phone then you just have to re add them
Abigail Hard -
will my number still be there and is the phone still active, Do I need to have it reactivated??
or should i take out the sim card first??
robcamp1963 - 답글
Now would I bypass a reset protection notification
STUDENT James Chapman - 답글
its work tnk u... : )
chandanso37 - 답글
It worked for me....thanks a whole lot.....am happy
Christian smart -
Its very Useful... Thank you.... -:)
Madhu K - 답글
It didn't work now I have a sad face on the screen and phone won't cut on
Monicia - 답글
It does not work!!
Katie Frisby - 답글
me too it does not work! and why ?
queeniebautista - 답글
It works.. Thanksss... :)
syedhuzaifa96 - 답글
Thanks a million. It worked and a huge problem solved. Thanks again.
Ibrahim Nisar - 답글
When I turn on my Lumia 630, it displays "Nokia" and goes off then comes on again and only display Nokia....will this method bring it back to normal?
Christian smart - 답글
Mine is the same too. I don't know what to do
Frank Inyiama -
It worked... thanks a bunch
It's not working, I repeated the process multiple times and I keep getting the same outcome, it just goes to the Nokia screen, and boots up the same
Anthony Martin - 답글
I have done it but still facing the same problem. The problem is that my sister has given me Nokia Lumia 635 and it is having a problem of ‘This device is locked to a specific mobile operator. Contact your mobile operator for the unlock code.
Beal Geesus - 답글
This method always had worked for me.
Manheche Baptista - 답글
This method always really worked for me.
thank you very much. the method is really superb
sssebyongaabdulnoor - 답글
Not work for me. Hardware reset done. anyway thanks for the details.
Pabodha Lankathilaka - 답글
There is a sad face and the phone won't start
Henry Ncube - 답글
Phone shows a sad face and will not open
Henry Ncube - 답글
the phone loads up to a blue screen then says complete and also says below it if you'd like to know more you can search online later or this and onto of that it says 0% then error.0xc00002e3
carlos gonzalez - 답글
It’s doesn’t work!
Sophia Parsons - 답글
how on god’s green earth are you going to do this “to reassemble your device follow this backward” bro, it’s a Fudging factory reset, not a dissasembaly
alexgamertheminer - 답글
Hallo, ich habe noch ein altes Nokia RM 974 in grün. Ich habe einen Hard-Reset durchgeführt. Nach den beiden Zahnrädern kommt aber leider nur ein ablehnendes und es resettet neu, und alles wiederholt sich. Haben Sie dafür eine Lösung?
Ralf Hader - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 43
30일 전: 206
전체 시간: 238,038
