주요 콘텐츠로 건너뛰기
Nokia Lumia 635 630 Display Assembly Replacement with Frame
필요한 것
동영상 개요
  1. Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: 1 단계, 이미지 1/3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: 1 단계, 이미지 2/3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: 1 단계, 이미지 3/3
    • Remove the battery and any SIM and memory cards.
    • Remove the black sticker at the bottom side of the phone.
  2. Nokia Lumia 635 630 Display Assembly Replacement with Frame: 2 단계, 이미지 1/3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: 2 단계, 이미지 2/3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: 2 단계, 이미지 3/3
    • Use a screwdriver Torx T4 and remove the 7x screws.
    • There are two other smaller screws with the same head size – remove them as well.
    You need a decent quality T4 screwdriver here - the rubbish on that cm free with the screen assembly I bought failed completely to grip or loosen the screws. With one from a decent set (ForgeSteel from ScrewFix) they came out easily. A fridge magnet is useful to keep the screws on.
    jeremyyoung - 답글
  3. Nokia Lumia 635 630 Display Assembly Replacement with Frame: 3 단계, 이미지 1/3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: 3 단계, 이미지 2/3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: 3 단계, 이미지 3/3
    • Lift the rear bezel and unhook the display assembly flex cable.
    • Don't use a metal tool for disconnecting the flex cable. There are many small elements near the connectors. You could break them. If you don't have a suitable tool just use your nails.
    • Now we have to transfer the earpiece.
  4. Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: 4 단계, 이미지 1/3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: 4 단계, 이미지 2/3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: 4 단계, 이미지 3/3
    • Put the earpiece on the new display assembly and start with reassembling.
결론
다른 17명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,278 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 2개
Where do i get the part replacements from to replace the screen and what not?
Nathaniel Ogungbuyi - 답글
Großes Lob an Nokia, das ist noch ein super zu öffnendes Smartphone gewesen! Touchdisplay tauschen war einfach.
Tale Spinner - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 10,325
