주요 콘텐츠로 건너뛰기
Nokia Lumia 635 Display Assembly Replacement
필요한 것
동영상 개요
  1. Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: 1 단계, 이미지 1/3 Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: 1 단계, 이미지 2/3 Nokia Lumia 635 Display Assembly Replacement, BATTERY, SIM AND MEMORY CARDS: 1 단계, 이미지 3/3
    • Switch off the phone.
    • Remove the battery and any installed SIM and memory cards.
    • Remove the black tape near to the loudspeaker.
  2. Nokia Lumia 635 Display Assembly Replacement, SCREWS: 2 단계, 이미지 1/3 Nokia Lumia 635 Display Assembly Replacement, SCREWS: 2 단계, 이미지 2/3 Nokia Lumia 635 Display Assembly Replacement, SCREWS: 2 단계, 이미지 3/3
    • Remove the 9x Torx T4 screws.
    • Two of them are with the same head size but with a different length.
  3. Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: 3 단계, 이미지 1/3 Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: 3 단계, 이미지 2/3 Nokia Lumia 635 Display Assembly Replacement, REAR COVER / BEZEL: 3 단계, 이미지 3/3
    • Use a plastic opening tool to remove the back cover.
    • Careful unhook the display assembly flex cable.
  4. Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: 4 단계, 이미지 1/3 Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: 4 단계, 이미지 2/3 Nokia Lumia 635 Display Assembly Replacement, TESTING THE NEW SPARE PART: 4 단계, 이미지 3/3
    • Insert wisdom here.
    Not sure if Step 4 'testing' is on the right place. I would assume it's after Step 7 ?
    deRahier - 답글
  5. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: 5 단계, 이미지 1/2 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 1: 5 단계, 이미지 2/2
    • Put some scotch tape to prevent the glass from scattering.
    • Use a hot gun or hair dryer and warm the glass to soften the adhesive.
  6. Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: 6 단계, 이미지 1/3 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: 6 단계, 이미지 2/3 Nokia Lumia 635 Display Assembly Replacement, DISPLAY ASSEMBLY STEP 2: 6 단계, 이미지 3/3
    • Start the separating from the upper right corner, where you have an hole in the middle frame.
    • Use plastic tool to prevent the middle frame from scratches.
    • Work slowly, you can cut your fingers.
  7. Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: 7 단계, 이미지 1/3 Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: 7 단계, 이미지 2/3 Nokia Lumia 635 Display Assembly Replacement, MIDDLE FRAME: 7 단계, 이미지 3/3
    • Clean the middle farme.
    • Put adhesive tape 3MM.
    • Be careful, don't cover the technological openings on the middle frame (for the light sensor, earpiece, etc.).
    • It's easier if you order the spare part together with an adhesive tape.
    • Install the display assembly.
  8. Nokia Lumia 635 Display Assembly Replacement: 8 단계, 이미지 1/2 Nokia Lumia 635 Display Assembly Replacement: 8 단계, 이미지 2/2
    • That's all.
    • Did you do it successfully?
결론
다른 5명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,182 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,520개 작성하였습니다
댓글 2개
Exactly what I needed! Step by step detailed instructions along with what tools I would need. Heating it up took longer than expected & it took me longer than 30 min, but I actually set aside 2 hours to replace my screen. Woohoo I finally I have a new screen & I did it all on my own...well with the amazing help from ZFix ;D
beatriz_ibre - 답글
how to fix the display
Roneil Mcintosh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 9,810
