주요 콘텐츠로 건너뛰기
Nokia Lumia 635 Headphone Jack Replacement
필요한 것
  1. Nokia Lumia 635 Headphone Jack Replacement, Battery Removal: 1 단계, 이미지 1/2 Nokia Lumia 635 Headphone Jack Replacement, Battery Removal: 1 단계, 이미지 2/2
    • Open the back case of the phone using the plastic opening tool.
    • Remove the battery.
  2. Nokia Lumia 635 Headphone Jack Replacement, Screw Removal: 2 단계, 이미지 1/2 Nokia Lumia 635 Headphone Jack Replacement, Screw Removal: 2 단계, 이미지 2/2
    • Remove the six screws shown in the photo using the torx Screwdriver 5mm.
    • Turn your phone sideways and you will find two more screws that you will need to remove using the Torx Screwdriver 5mm.
  3. Nokia Lumia 635 Headphone Jack Replacement, Remove Hidden Screw: 3 단계, 이미지 1/2 Nokia Lumia 635 Headphone Jack Replacement, Remove Hidden Screw: 3 단계, 이미지 2/2
    • Remove the black sticker on the bottom left side (As shown in the picture).
    • Remove the screw that was under the black sticker using the Torx Screwdriver 5mm.
  4. Nokia Lumia 635 Headphone Jack Replacement, Separating Back Cover From Screen: 4 단계, 이미지 1/1
    • Using the plastic opening tool separate the plastic cover from the screen.
    • On the top left corner you will see the screens flex attached to the mother bothered, watch out when separating them.
  5. Nokia Lumia 635 Headphone Jack Replacement, Audio Jack Replacement: 5 단계, 이미지 1/1
    • Carefully retrieve the audio jack’s flex that is attached to the mother board as shown in the picture.
    • Attach the new audio jack’s flex to the mother board.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Benjamin
회원 가입일: 10/07/14
173 평판
안내서 1개 작성함
USF Tampa, Team 7-1, Leahy Fall 2014 USF Tampa, Team 7-1, Leahy Fall 2014 회원
USFT-LEAHY-F14S7G1
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
where can you buy the headphone jack?
fERD - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 13
전체 시간: 4,914
