주요 콘텐츠로 건너뛰기
Nokia Lumia 720 Battery Replacement
필요한 것
동영상 개요
  1. Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 1: 1 단계, 이미지 1/3 Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 1: 1 단계, 이미지 2/3 Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 1: 1 단계, 이미지 3/3
    • Remove the SIM card tray and the memory card try.
    • Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
    • Use plastic tools and start the separating the back cover from the top side.
  2. Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 2: 2 단계, 이미지 1/3 Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 2: 2 단계, 이미지 2/3 Nokia Lumia 720 Battery Replacement, BATTERY COVER - PART 2: 2 단계, 이미지 3/3
    • Be careful with the volume buttons.
  3. Nokia Lumia 720 Battery Replacement, Loudspeaker & Antenna module: 3 단계, 이미지 1/3 Nokia Lumia 720 Battery Replacement, Loudspeaker & Antenna module: 3 단계, 이미지 2/3 Nokia Lumia 720 Battery Replacement, Loudspeaker & Antenna module: 3 단계, 이미지 3/3
    • Remove the 3x Torx T4 screws.
    • Buzzer / Loudspeacker
  4. Nokia Lumia 720 Battery Replacement, BATTERY: 4 단계, 이미지 1/3 Nokia Lumia 720 Battery Replacement, BATTERY: 4 단계, 이미지 2/3 Nokia Lumia 720 Battery Replacement, BATTERY: 4 단계, 이미지 3/3
    • Disconnect the battery flex cable.
    • Unstick the metal foil from the logic board.
    • Use a plastic tool with a thin tip and unstuck the battery from the middle frame.
    • Battery - BP-4GWA, 2000mAh, 3.7V, 7.4Vh
결론
다른 한 분이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,203 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,523개 작성하였습니다
댓글 3개
I have nokia lumia 720....it can't starting up only shows charging sing..... plz...help me
Amir Hosain - 답글
i have also the same problem is ur problem fixed now ..then pls tell me the solution
pattnayakabhash34 -
Hey guys I really need to know if you can recommend a trusted retailer of spare BP-4GWA here in South East Asia. I am currently residing in the Philippines and it's just hard to buy from Ebay and Alibaba without anyone's opinion. TIA!
nicoangelob - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 5,641
