소개
Nokia Lumia 720 - How to replace Coaxial Antenna Cable.
동영상 개요
  1. Remove the SIM card tray and the memory card try. Use a screwdriver Torx T2 and remove the screw under the SIM card tray. Use plastic tools and start the separating the back cover from the top side.
    • Remove the SIM card tray and the memory card try.
    • Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
    • Use plastic tools and start the separating the back cover from the top side.
  2. Be careful with the volume buttons. Be careful with the volume buttons. Be careful with the volume buttons.
    • Be careful with the volume buttons.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Remove the 3x Torx T4 screws. Buzzer / Loudspeacker Buzzer / Loudspeacker
    • Remove the 3x Torx T4 screws.
    • Buzzer / Loudspeacker
  5. Disconnect the Antenna cable from the Logic board and from the Charging Dock board and remove it. Disconnect the Antenna cable from the Logic board and from the Charging Dock board and remove it. Disconnect the Antenna cable from the Logic board and from the Charging Dock board and remove it.
    • Disconnect the Antenna cable from the Logic board and from the Charging Dock board and remove it.
결론
ZFix
회원 가입일: 2013년 12월 09일
164,056 평판
안내서 305개 작성하였습니다
Master Techs Master Techs 회원
Community
286 회원들
안내서 808개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 780
