주요 콘텐츠로 건너뛰기
Nokia Lumia 720 Display Assembly Replacement
필요한 것
동영상 개요
  1. Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 1: 1 단계, 이미지 1/3 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 1: 1 단계, 이미지 2/3 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 1: 1 단계, 이미지 3/3
    • Remove the SIM card tray and the memory card try.
    • Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
    • Use plastic tools and start the separating the back cover from the top side.
  2. Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 2: 2 단계, 이미지 1/3 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 2: 2 단계, 이미지 2/3 Nokia Lumia 720 Display Assembly Replacement, BATTERY COVER - PART 2: 2 단계, 이미지 3/3
    • Be careful with the volume buttons.
  3. Nokia Lumia 720 Display Assembly Replacement, Loudspeaker & Antenna module: 3 단계, 이미지 1/3 Nokia Lumia 720 Display Assembly Replacement, Loudspeaker & Antenna module: 3 단계, 이미지 2/3 Nokia Lumia 720 Display Assembly Replacement, Loudspeaker & Antenna module: 3 단계, 이미지 3/3
    • Remove the 3x Torx T4 screws.
    • Buzzer / Loudspeacker
  4. Nokia Lumia 720 Display Assembly Replacement, BATTERY: 4 단계, 이미지 1/3 Nokia Lumia 720 Display Assembly Replacement, BATTERY: 4 단계, 이미지 2/3 Nokia Lumia 720 Display Assembly Replacement, BATTERY: 4 단계, 이미지 3/3
    • Disconnect the battery flex cable.
    • Unstick the metal foil from the logic board.
    • Use a plastic tool with a thin tip and unstuck the battery from the middle frame.
    • Battery - BP-4GWA, 2000mAh, 3.7V, 7.4Vh
  5. Nokia Lumia 720 Display Assembly Replacement, COAXIAL ANTENNA CABLE: 5 단계, 이미지 1/3 Nokia Lumia 720 Display Assembly Replacement, COAXIAL ANTENNA CABLE: 5 단계, 이미지 2/3 Nokia Lumia 720 Display Assembly Replacement, COAXIAL ANTENNA CABLE: 5 단계, 이미지 3/3
    • Disconnect the Antenna cable from the Logic board and from the Charging Dock board and remove it.
  6. Nokia Lumia 720 Display Assembly Replacement, Logic Board: 6 단계, 이미지 1/3 Nokia Lumia 720 Display Assembly Replacement, Logic Board: 6 단계, 이미지 2/3 Nokia Lumia 720 Display Assembly Replacement, Logic Board: 6 단계, 이미지 3/3
    • Disconnect the Volume, Power and camera buttons flex cable.
    • Remove the 4x Torx T4 screws.
    • Slightly lift the board
    • Slowly and gently unstuck the light sensor from the middle frame.
  7. Nokia Lumia 720 Display Assembly Replacement: 7 단계, 이미지 1/3 Nokia Lumia 720 Display Assembly Replacement: 7 단계, 이미지 2/3 Nokia Lumia 720 Display Assembly Replacement: 7 단계, 이미지 3/3
    • Disconnect the Display Assembly flex cable.
    • Disconnect the Charging Dock Board flex cable.
    • Remove the Main board.
  8. Nokia Lumia 720 Display Assembly Replacement, Charging Dock and Microphone Module: 8 단계, 이미지 1/3 Nokia Lumia 720 Display Assembly Replacement, Charging Dock and Microphone Module: 8 단계, 이미지 2/3 Nokia Lumia 720 Display Assembly Replacement, Charging Dock and Microphone Module: 8 단계, 이미지 3/3
    • Use a hair dryer and warm the flex cable.
    • Careful unstuck the flex cable from the middle frame.
    • Micro USB connector
    • Microphone
  9. Nokia Lumia 720 Display Assembly Replacement, EARPIECE: 9 단계, 이미지 1/2 Nokia Lumia 720 Display Assembly Replacement, EARPIECE: 9 단계, 이미지 2/2
    • Use a tool with a sharp point and carefully unstuck the earpiece.
  10. Nokia Lumia 720 Display Assembly Replacement, Power, Volume and Camera buttons flex cable: 10 단계, 이미지 1/3 Nokia Lumia 720 Display Assembly Replacement, Power, Volume and Camera buttons flex cable: 10 단계, 이미지 2/3 Nokia Lumia 720 Display Assembly Replacement, Power, Volume and Camera buttons flex cable: 10 단계, 이미지 3/3
    • When you start with the removing the ribbon cable be careful with the buttons and with the small black cups on it.
    • Warm the flex cable and detach it.
  11. Nokia Lumia 720 Display Assembly Replacement, Display Assembly: 11 단계, 이미지 1/3 Nokia Lumia 720 Display Assembly Replacement, Display Assembly: 11 단계, 이미지 2/3 Nokia Lumia 720 Display Assembly Replacement, Display Assembly: 11 단계, 이미지 3/3
    • Now you can start with the reassembling, but before you place the back cover, test the new display assembly.
    • When you put the lid be careful with the volume buttons.
  12. Nokia Lumia 720 Display Assembly Replacement: 12 단계, 이미지 1/1
    • That's all.
    • Did you do it successfully?
결론
다른 5명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,308 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 5,802
