주요 콘텐츠로 건너뛰기
Nokia Lumia 720 Power, Volume and Camera buttons flex cable Replacement
필요한 것
동영상 개요
  1. Nokia Lumia 720 Power, Volume and Camera buttons flex cable Replacement, BATTERY COVER - PART 1: 1 단계, 이미지 1/3 Nokia Lumia 720 Power, Volume and Camera buttons flex cable Replacement, BATTERY COVER - PART 1: 1 단계, 이미지 2/3 Nokia Lumia 720 Power, Volume and Camera buttons flex cable Replacement, BATTERY COVER - PART 1: 1 단계, 이미지 3/3
    • Remove the SIM card tray and the memory card try.
    • Use a screwdriver Torx T2 and remove the screw under the SIM card tray.
    • Use plastic tools and start the separating the back cover from the top side.
  2. Nokia Lumia 720 Power, Volume and Camera buttons flex cable Replacement, BATTERY COVER - PART 2: 2 단계, 이미지 1/3 Nokia Lumia 720 Power, Volume and Camera buttons flex cable Replacement, BATTERY COVER - PART 2: 2 단계, 이미지 2/3 Nokia Lumia 720 Power, Volume and Camera buttons flex cable Replacement, BATTERY COVER - PART 2: 2 단계, 이미지 3/3
    • Be careful with the volume buttons.
  3. Nokia Lumia 720 Power, Volume and Camera buttons flex cable Replacement, Power, Volume and Camera buttons flex cable: 3 단계, 이미지 1/3 Nokia Lumia 720 Power, Volume and Camera buttons flex cable Replacement, Power, Volume and Camera buttons flex cable: 3 단계, 이미지 2/3 Nokia Lumia 720 Power, Volume and Camera buttons flex cable Replacement, Power, Volume and Camera buttons flex cable: 3 단계, 이미지 3/3
    • When you start with the removing the ribbon cable be careful with the buttons and with the small black cups on it.
    • Warm the flex cable and detach it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,308 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,539개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 5
30일 전: 6
전체 시간: 2,468
