주요 콘텐츠로 건너뛰기
Nokia Lumia 830 Battery Replacement
필요한 것
  1. Nokia Lumia 830 Battery Replacement, Battery: 1 단계, 이미지 1/2 Nokia Lumia 830 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Place the phone with the screen facing down.
    • Remove the back cover by placing your fingernail or plastic opening tool under the slotted indent at the bottom of the phone.
  2. Nokia Lumia 830 Battery Replacement: 2 단계, 이미지 1/3 Nokia Lumia 830 Battery Replacement: 2 단계, 이미지 2/3 Nokia Lumia 830 Battery Replacement: 2 단계, 이미지 3/3
    • Carefully remove the battery by placing the plastic opening tool underneath the indent at the bottom of the battery, and pry it up.
    • There may be adhesive underneath the battery to keep it in place, this may make it a bit difficult to remove the battery.
결론
Adam Mack
회원 가입일: 10/04/16
284 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-2, Sullivan Fall 2016 USF Tampa, Team 1-2, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S1G2
3 회원들
안내서 11개 작성하였습니다
댓글 한 개
Hi, i’ve bought a battery from amazon to this phone. It has the same specs as the old one, but when i put it to charge (on the phone) it only charges untill half and it stays there. Do i need to buy a different battery or is there a way to fix this?
Eduardo Teixeira - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 1,400
