주요 콘텐츠로 건너뛰기
Nokia Lumia 830 Main Speaker Replacement
필요한 것
  1. Nokia Lumia 830 Main Speaker Replacement, Battery: 1 단계, 이미지 1/2 Nokia Lumia 830 Main Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Place the phone with the screen facing down.
    • Remove the back cover by placing your fingernail or plastic opening tool under the slotted indent at the bottom of the phone.
  2. Nokia Lumia 830 Main Speaker Replacement: 2 단계, 이미지 1/3 Nokia Lumia 830 Main Speaker Replacement: 2 단계, 이미지 2/3 Nokia Lumia 830 Main Speaker Replacement: 2 단계, 이미지 3/3
    • Carefully remove the battery by placing the plastic opening tool underneath the indent at the bottom of the battery, and pry it up.
    • There may be adhesive underneath the battery to keep it in place, this may make it a bit difficult to remove the battery.
  3. Nokia Lumia 830 Main Speaker Replacement, Main Speaker: 3 단계, 이미지 1/2 Nokia Lumia 830 Main Speaker Replacement, Main Speaker: 3 단계, 이미지 2/2
    • Remove the black strips on both sides of the battery compartment.
  4. Nokia Lumia 830 Main Speaker Replacement: 4 단계, 이미지 1/2 Nokia Lumia 830 Main Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the two 3.9mm silver screws from the bottom corner of the phone. Then remove the five 2.5mm black screws from top to bottom of the phone.
    • All of the screws take a t5 star screwdriver.
  5. Nokia Lumia 830 Main Speaker Replacement: 5 단계, 이미지 1/3 Nokia Lumia 830 Main Speaker Replacement: 5 단계, 이미지 2/3 Nokia Lumia 830 Main Speaker Replacement: 5 단계, 이미지 3/3
    • Use the plastic opening tool to push into the slots holding the backing in place.
    • All five slots are along the inner wall of the battery compartment. Push the slots on the sides first before pushing the slot on the top.
    • Remove the backing from the frame, making sure to lift the bottom portion away from the phone, to allow the top to slide out of place.
  6. Nokia Lumia 830 Main Speaker Replacement: 6 단계, 이미지 1/1
    • Lift the speaker out of the phone. You may need to wiggle the speaker loose.
결론
saydeking
회원 가입일: 10/03/16
527 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-2, Sullivan Fall 2016 USF Tampa, Team 1-2, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S1G2
3 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 860
