주요 콘텐츠로 건너뛰기
Nokia Lumia 900 Battery Replacement
필요한 것
  1. 주의: 1 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
    Nokia Lumia 900 Battery Replacement, Opening The Phone: 1 단계, 이미지 1/2 Nokia Lumia 900 Battery Replacement, Opening The Phone: 1 단계, 이미지 2/2
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Nokia Lumia 900 Battery Replacement, Remove Old Battery: 2 단계, 이미지 1/1
    • Detach connector A from the phone.
    • Use the opening tool to pry out battery from the phone.
    • The battery should come out fairly easily
  3. Nokia Lumia 900 Battery Replacement, Installing New Battery: 3 단계, 이미지 1/1
    • Place the battery in the empty battery slot
    • Attach connector A to the battery terminal.
  4. Nokia Lumia 900 Battery Replacement, Reassembling The Screen: 4 단계, 이미지 1/1
    • Slide the hinges of the left side of the screen under the left side of the plastic case
    • Clamp the right side of the screen down and make sure screen is flat
    • The screen should "click" into place
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Joshua Crosman
회원 가입일: 10/20/14
304 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S5G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 2,884
