주요 콘텐츠로 건너뛰기
Nokia Lumia 900 Front Camera Replacement
필요한 것
  1. 주의: 1 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
    Nokia Lumia 900 Front Camera Replacement, Opening The Phone: 1 단계, 이미지 1/2 Nokia Lumia 900 Front Camera Replacement, Opening The Phone: 1 단계, 이미지 2/2
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Nokia Lumia 900 Front Camera Replacement, Detach Ribbon: 2 단계, 이미지 1/1
    • Detach camera ribbon from motherboard
  3. Nokia Lumia 900 Front Camera Replacement, Remove Camera: 3 단계, 이미지 1/1
    • Peel camera off of adhesive surface
    • Use caution when removing camera as it is fragile
  4. Nokia Lumia 900 Front Camera Replacement, Installing New Camera: 4 단계, 이미지 1/1
    • Apply adhesive to back of camera
    • Attach ribbon to motherboard
    • Press down on camera for 60 seconds
    • Let dry for 5 minutes
  5. Nokia Lumia 900 Front Camera Replacement, Reassembling Screen: 5 단계, 이미지 1/1
    • Slide the hinges of the left side of the screen under the left side of the plastic case
    • Clamp the right side of the screen down and make sure screen is flat
    • The screen should "click" into place
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joshua Crosman
회원 가입일: 10/20/14
304 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S5G1
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Is also forgot to tell about the plate between screen and battery that is glued to the battery
John Bork - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 566
