주요 콘텐츠로 건너뛰기
Nokia Lumia 900 Motherboard Replacement
필요한 것
  1. 주의: 1 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
    Nokia Lumia 900 Motherboard Replacement, Opening The Phone: 1 단계, 이미지 1/2 Nokia Lumia 900 Motherboard Replacement, Opening The Phone: 1 단계, 이미지 2/2
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Nokia Lumia 900 Motherboard Replacement, Removing the Battery: 2 단계, 이미지 1/1
    • Detach connector from the phone.
    • Use the opening tool to pry out battery from the phone.
    • The battery should come out fairly easily
  3. Nokia Lumia 900 Motherboard Replacement, Detach the Screen: 3 단계, 이미지 1/1
    • Detach Connectors that are attached from the screen to the motherboard.
    • Screen can now be removed with little effort.
  4. Nokia Lumia 900 Motherboard Replacement, Removing Rubber Gaskets: 4 단계, 이미지 1/1
    • Using a pair of tweezers, remove rubber gaskets that are holding the motherboard in place.
  5. Nokia Lumia 900 Motherboard Replacement, Removing the Motherboard: 5 단계, 이미지 1/1
    • Starting in the bottom left corner of the device, insert a wedge between the motherboard and the case.
    • Gently pull up with the wedge allowing for the motherboard to gently click out of place.
    • Gradually repeat this process around the entire motherboard until it becomes easy enough to remove completley from the casing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Joshua Crosman
회원 가입일: 10/20/14
304 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S5G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 6
전체 시간: 1,636
