주요 콘텐츠로 건너뛰기
Nokia Lumia 900 Screen Replacement
필요한 것
  1. Nokia Lumia 900 Screen  Replacement, Screen: 1 단계, 이미지 1/2 Nokia Lumia 900 Screen  Replacement, Screen: 1 단계, 이미지 2/2
    • Insert the pointed end of the spudger into the sim card port indicated by the picture. Then proceed to remove the sim card port entirely.
  2. Nokia Lumia 900 Screen  Replacement: 2 단계, 이미지 1/2 Nokia Lumia 900 Screen  Replacement: 2 단계, 이미지 2/2
    • Use tweezers to remove the small rod in the port indicated in the picture.
  3. Nokia Lumia 900 Screen  Replacement: 3 단계, 이미지 1/2 Nokia Lumia 900 Screen  Replacement: 3 단계, 이미지 2/2
    • Separate the screen from the motherboard by prying it open with the spudger along with pulling upwards with the suction cup.
  4. Nokia Lumia 900 Screen  Replacement: 4 단계, 이미지 1/2 Nokia Lumia 900 Screen  Replacement: 4 단계, 이미지 2/2
    • Gently pull apart the screen from the motherboard, with only the ribbons connected from the motherboard to the screen.
  5. Nokia Lumia 900 Screen  Replacement: 5 단계, 이미지 1/1
    • Disconnect the No-fuss cables from the motherboard by gently prying them up using the flat end of the black stick spudger. Make sure not to bend or crease the cable.
    • Remove the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tyler Bui
회원 가입일: 02/15/17
117 평판
안내서 1개 작성함
USF Tampa, Team 10-6, Remmell Spring 2017 USF Tampa, Team 10-6, Remmell Spring 2017 회원
USFT-REMMELL-S17S10G6
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 15
전체 시간: 869
