필요한 것
1 단계 Opening The Phone
주의: 1 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
Using the opening tool, pry the screen from the casing until they are separated from each other.
Attach new screen connectors to logic board
Slide the hinges of the left side of the screen under the left side of the plastic case
Clamp the right side of the screen down and make sure screen is flat
The screen should "click" into place
다른 3명이 해당 안내서를 완성하였습니다.
