주요 콘텐츠로 건너뛰기
Nokia Lumia 925 Display Replacement
필요한 것
  1. Nokia Lumia 925 Display Replacement, Motherboard: 1 단계, 이미지 1/2 Nokia Lumia 925 Display Replacement, Motherboard: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the sim card holder by inserting tweezers into the hole. Push down and the holder will spring back up.
    • Pull out the holder until it is completely separate.
    • Something like a paperclip will work if there are no tweezers available.
  2. Nokia Lumia 925 Display Replacement: 2 단계, 이미지 1/3 Nokia Lumia 925 Display Replacement: 2 단계, 이미지 2/3 Nokia Lumia 925 Display Replacement: 2 단계, 이미지 3/3
    • Slide a plastic opening tool under the back cover.
    • Slide the tool around the outsides of the cover to fully dislodge the pins holding the cover to the phone.
    • Some pins are facing the opposite way from the others.
  3. Nokia Lumia 925 Display Replacement: 3 단계, 이미지 1/3 Nokia Lumia 925 Display Replacement: 3 단계, 이미지 2/3 Nokia Lumia 925 Display Replacement: 3 단계, 이미지 3/3
    • Remove the 3 screws using the T7 Torx screwdriver.
    • Unclip the black tab connector.
  4. Nokia Lumia 925 Display Replacement: 4 단계, 이미지 1/2 Nokia Lumia 925 Display Replacement: 4 단계, 이미지 2/2
    • Remove the silver metal cover.
    • Be careful of the tape under the right square side of the panel. Using a spudger helps.
  5. Nokia Lumia 925 Display Replacement: 5 단계, 이미지 1/3 Nokia Lumia 925 Display Replacement: 5 단계, 이미지 2/3 Nokia Lumia 925 Display Replacement: 5 단계, 이미지 3/3
    • Unclip the two orange tabs.
    • Remove the four silver screws using the T5 Torx screwdriver.
  6. Nokia Lumia 925 Display Replacement: 6 단계, 이미지 1/2 Nokia Lumia 925 Display Replacement: 6 단계, 이미지 2/2
    • Remove the motherboard by sliding tweezers between it and the back of the screen. Lift up.
  7. Nokia Lumia 925 Display Replacement, Display: 7 단계, 이미지 1/2 Nokia Lumia 925 Display Replacement, Display: 7 단계, 이미지 2/2
    • Push the screen from the inside of the phone.
    • Pull the screen off.
    • Slide the electronic strip through the small opening.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Guillermo Lara
회원 가입일: 09/18/18
409 평판
안내서 3개 작성하였습니다
University of North Texas, Team S4-G6, Raign Fall 2018 University of North Texas, Team S4-G6, Raign Fall 2018 회원
UNT-RAIGN-F18S4G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 866
