주요 콘텐츠로 건너뛰기
Nokia Lumia 925 Front Camera Replacement
필요한 것
  1. Nokia Lumia 925 Front Camera Replacement, Motherboard: 1 단계, 이미지 1/2 Nokia Lumia 925 Front Camera Replacement, Motherboard: 1 단계, 이미지 2/2
    • Remove the sim card holder by inserting tweezers into the hole. Push down and the holder will spring back up.
    • Pull out the holder until it is completely separate.
    • Something like a paperclip will work if there are no tweezers available.
  2. Nokia Lumia 925 Front Camera Replacement: 2 단계, 이미지 1/3 Nokia Lumia 925 Front Camera Replacement: 2 단계, 이미지 2/3 Nokia Lumia 925 Front Camera Replacement: 2 단계, 이미지 3/3
    • Slide a plastic opening tool under the back cover.
    • Slide the tool around the outsides of the cover to fully dislodge the pins holding the cover to the phone.
    • Some pins are facing the opposite way from the others.
  3. Nokia Lumia 925 Front Camera Replacement: 3 단계, 이미지 1/3 Nokia Lumia 925 Front Camera Replacement: 3 단계, 이미지 2/3 Nokia Lumia 925 Front Camera Replacement: 3 단계, 이미지 3/3
    • Remove the 3 screws using the T7 Torx screwdriver.
    • Unclip the black tab connector.
  4. Nokia Lumia 925 Front Camera Replacement: 4 단계, 이미지 1/2 Nokia Lumia 925 Front Camera Replacement: 4 단계, 이미지 2/2
    • Remove the silver metal cover.
    • Be careful of the tape under the right square side of the panel. Using a spudger helps.
  5. Nokia Lumia 925 Front Camera Replacement: 5 단계, 이미지 1/3 Nokia Lumia 925 Front Camera Replacement: 5 단계, 이미지 2/3 Nokia Lumia 925 Front Camera Replacement: 5 단계, 이미지 3/3
    • Unclip the two orange tabs.
    • Remove the four silver screws using the T5 Torx screwdriver.
  6. Nokia Lumia 925 Front Camera Replacement: 6 단계, 이미지 1/2 Nokia Lumia 925 Front Camera Replacement: 6 단계, 이미지 2/2
    • Remove the motherboard by sliding tweezers between it and the back of the screen. Lift up.
  7. Nokia Lumia 925 Front Camera Replacement, Display: 7 단계, 이미지 1/2 Nokia Lumia 925 Front Camera Replacement, Display: 7 단계, 이미지 2/2
    • Push the screen from the inside of the phone.
    • Pull the screen off.
    • Slide the electronic strip through the small opening.
  8. Nokia Lumia 925 Front Camera Replacement, Speaker: 8 단계, 이미지 1/1
    • Locate the grey speaker/camera cover.
    • Carefully remove the cover with either a pair of tweezers or your fingers.
  9. Nokia Lumia 925 Front Camera Replacement: 9 단계, 이미지 1/3 Nokia Lumia 925 Front Camera Replacement: 9 단계, 이미지 2/3 Nokia Lumia 925 Front Camera Replacement: 9 단계, 이미지 3/3
    • With a pair of tweezers, gently remove the orange colored tab closest to the speaker.
  10. Nokia Lumia 925 Front Camera Replacement, Front Camera: 10 단계, 이미지 1/1
    • Pull at the orange section until it becomes loose.
    • It is located in the upper leftmost section of the phone behind the front camera.
  11. Nokia Lumia 925 Front Camera Replacement: 11 단계, 이미지 1/1
    • Pull vertically on the same orange section until the front camera comes out.
    • The front camera as well as the speaker may come out after the last step so be careful.
결론
O'Ryan Lacour
회원 가입일: 09/18/18
85 평판
안내서 1개 작성함
University of North Texas, Team S4-G6, Raign Fall 2018 University of North Texas, Team S4-G6, Raign Fall 2018 회원
UNT-RAIGN-F18S4G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 187
