주요 콘텐츠로 건너뛰기
Nokia Lumia 928 Display Assembly Replacement
필요한 것
  1. Nokia Lumia 928 Display Assembly Replacement, Back Cover: 1 단계, 이미지 1/2 Nokia Lumia 928 Display Assembly Replacement, Back Cover: 1 단계, 이미지 2/2
    • Power down the phone.
    • There is a screw located inside the 3.5mm headphone jack that needs to be loosened. Use a Torx T5 screwdriver for this.
    • The screw does not come out. Once loosened, It will unlock the lock bar inside the phone. You will break it if you do not complete this step properly.
    • Remove the sim card tray on the top of the phone.
    • Remove the 4.5 mm Torx T5 screw highlighted with a red circle in the picture. (Note: all screws that you will remove in the phone will be the same)
    • There is a sticker located on the screw that needs to be peeled off. This voids your warranty.
  2. Nokia Lumia 928 Display Assembly Replacement: 2 단계, 이미지 1/3 Nokia Lumia 928 Display Assembly Replacement: 2 단계, 이미지 2/3 Nokia Lumia 928 Display Assembly Replacement: 2 단계, 이미지 3/3
    • Using the plastic opening tools, you can start to release the plastic clips around the phone. Start in the top left corner, work your way down the left side. Then do the top and bottom of the phone, and finally the right side.
    • It can be useful to flip the plastic opening tool upside down in certain areas of the phone to make releasing the plastic clips easier.
    • Once all the clips are released, remove the back cover of the phone.
  3. Nokia Lumia 928 Display Assembly Replacement, Motherboard: 3 단계, 이미지 1/1
    • Remove all 10 T5 screws on the motherboard. All screws are 4.5 mm Torx T5 screws.
  4. Nokia Lumia 928 Display Assembly Replacement: 4 단계, 이미지 1/2 Nokia Lumia 928 Display Assembly Replacement: 4 단계, 이미지 2/2
    • Remove the ribbon connector with a highlighted with a red circle with the plastic opening tool.
    • Be very careful with the ribbon connectors as they can easily be ripped off.
    • The ribbon connector highlighted in yellow has a zero insertion force connector. This has a black flap on the end that needs to be flipped up before the ribbon cable can be pulled out.
  5. Nokia Lumia 928 Display Assembly Replacement: 5 단계, 이미지 1/1
    • Remove USB port cover using the plastic opening tool, or your hand. It can be removed easily.
  6. Nokia Lumia 928 Display Assembly Replacement: 6 단계, 이미지 1/2 Nokia Lumia 928 Display Assembly Replacement: 6 단계, 이미지 2/2
    • Pull up the left side of the motherboard.
    • There is 1 connector that needs to be removed with the plastic opening tool highlighted with a red rectangle. Do not pull the motherboard away from the display assembly until you have removed it.
    • You have now removed the motherboard from the display assembly and the back cover.
  7. Nokia Lumia 928 Display Assembly Replacement, Display Assembly: 7 단계, 이미지 1/1
    • After following the steps for removing the motherboard, your display assembly can also be removed. These steps happen simultaneously.
    • Again, it's important to be careful in removing the ribbon cable before separating the display from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Casey
회원 가입일: 03/04/16
241 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 6-8, Bhusal Spring 2016 UMass Dartmouth, Team 6-8, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S6G8
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Be carefule in step 4, the red circled connector’s other side is attached by a pair of small plastic hooks to the motherboard. One of the hooks is very small and can be easily bent if that side comes off and has to be reattached.
Martin Doehring - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 11
전체 시간: 1,264
