소개
This guide involves following 2 previous guides for the Nokia Lumia 928. It will first show you how to remove the back cover from the device. Then, it will show you how to remove the motherboard, which will let you remove the display assembly. It involves removing some screws, and a little bit of patience to ensure the safety of your device.
필요한 것
Power down the phone.
There is a screw located inside the 3.5mm headphone jack that needs to be loosened. Use a Torx T5 screwdriver for this.
Remove the sim card tray on the top of the phone.
Remove the 4.5 mm Torx T5 screw highlighted with a red circle in the picture. (Note: all screws that you will remove in the phone will be the same)
Using the plastic opening tools, you can start to release the plastic clips around the phone. Start in the top left corner, work your way down the left side. Then do the top and bottom of the phone, and finally the right side.
Once all the clips are released, remove the back cover of the phone.
Remove all 10 T5 screws on the motherboard. All screws are 4.5 mm Torx T5 screws.
After following the steps for removing the motherboard, your display assembly can also be removed. These steps happen simultaneously.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Be carefule in step 4, the red circled connector’s other side is attached by a pair of small plastic hooks to the motherboard. One of the hooks is very small and can be easily bent if that side comes off and has to be reattached.
