주요 콘텐츠로 건너뛰기
Nokia N70 Back Camera Replacement
필요한 것
  1. Nokia N70 Back Camera Replacement, Battery: 1 단계, 이미지 1/1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Back Camera Replacement: 2 단계, 이미지 1/1
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Back Camera Replacement: 3 단계, 이미지 1/1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Back Camera Replacement: 4 단계, 이미지 1/1
    • Remove the battery from the phone.
  5. Nokia N70 Back Camera Replacement, Keypad: 5 단계, 이미지 1/3 Nokia N70 Back Camera Replacement, Keypad: 5 단계, 이미지 2/3 Nokia N70 Back Camera Replacement, Keypad: 5 단계, 이미지 3/3
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Back Camera Replacement: 6 단계, 이미지 1/3 Nokia N70 Back Camera Replacement: 6 단계, 이미지 2/3 Nokia N70 Back Camera Replacement: 6 단계, 이미지 3/3
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
  7. Nokia N70 Back Camera Replacement, Back Camera: 7 단계, 이미지 1/2 Nokia N70 Back Camera Replacement, Back Camera: 7 단계, 이미지 2/2
    • Using T6 Torx screwdriver remove the six 15 mm torx screws.
  8. Nokia N70 Back Camera Replacement: 8 단계, 이미지 1/3 Nokia N70 Back Camera Replacement: 8 단계, 이미지 2/3 Nokia N70 Back Camera Replacement: 8 단계, 이미지 3/3
    • Separate the front panel from the back by lifting the bottom of the front panel at a 45 degree angle.
    • Remove the front panel by lifting the panel away from the phone at a 45 degree angle.
  9. Nokia N70 Back Camera Replacement: 9 단계, 이미지 1/3 Nokia N70 Back Camera Replacement: 9 단계, 이미지 2/3 Nokia N70 Back Camera Replacement: 9 단계, 이미지 3/3
    • Locate the rear circuit board by flipping over the front panel.
    • Locate the rear camera and by using the plastic opening tool, gently lift the camera out of the slot.
    • Caution: Be careful when prying camera out of the slot for the connections are fragile.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Justin
회원 가입일: 10/12/11
984 평판
안내서 5개 작성하였습니다
Cal Poly, Team 6-2, Regan Fall 2011 Cal Poly, Team 6-2, Regan Fall 2011 회원
CPSU-REGAN-F11S6G2
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
mon nokia n70 est mal camera alors quest -ce qu*on va faire
sidiahmed ahmed - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 19
전체 시간: 8,811
