주요 콘텐츠로 건너뛰기
Nokia N70 Keypad Replacement
필요한 것
  1. Nokia N70 Keypad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Keypad Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Keypad Replacement: 3 단계, 이미지 1개 중 1개
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Keypad Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the battery from the phone.
  5. Nokia N70 Keypad Replacement, Keypad: 5 단계, 이미지 3개 중 1개 Nokia N70 Keypad Replacement, Keypad: 5 단계, 이미지 3개 중 2개 Nokia N70 Keypad Replacement, Keypad: 5 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Keypad Replacement: 6 단계, 이미지 3개 중 1개 Nokia N70 Keypad Replacement: 6 단계, 이미지 3개 중 2개 Nokia N70 Keypad Replacement: 6 단계, 이미지 3개 중 3개
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
결론
작성자
6다른 기여자 명과 함께
Justin
회원 가입일: 10/12/11
1,026 평판
안내서 5개를 작성함
Cal Poly, Team 6-2, Regan Fall 2011 Cal Poly, Team 6-2, Regan Fall 2011 회원
CPSU-REGAN-F11S6G2
4 회원들
안내서 11개를 작성함
1가이드 댓글
I have N70 nokia mobile. Its keypad buttons 1, 2 & C and also left key and upper key is not working
please give me solution how to solve this problem
Imamuddin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 22
전체 시간: 4,231
