주요 콘텐츠로 건너뛰기
Nokia N9 Battery Replacement
필요한 것
  1. Nokia N9 Battery Replacement, remove top parts: 1 단계, 이미지 1/3 Nokia N9 Battery Replacement, remove top parts: 1 단계, 이미지 2/3 Nokia N9 Battery Replacement, remove top parts: 1 단계, 이미지 3/3
    • Click open the USB input protector lid and pull it from the housing.
    • Also remove the SIM card holder.
    • Remove screws from the top using the T3 torx screwdriver.
  2. Nokia N9 Battery Replacement, loosen the screen: 2 단계, 이미지 1/3 Nokia N9 Battery Replacement, loosen the screen: 2 단계, 이미지 2/3 Nokia N9 Battery Replacement, loosen the screen: 2 단계, 이미지 3/3
    • Press your screwdriver against the backside of the white pieces of plastic, and the screen will click out at the top side of the phone.
  3. Nokia N9 Battery Replacement, disconnect screen from phone: 3 단계, 이미지 1/3 Nokia N9 Battery Replacement, disconnect screen from phone: 3 단계, 이미지 2/3 Nokia N9 Battery Replacement, disconnect screen from phone: 3 단계, 이미지 3/3
    • Using a plastic tool, carefully open up the distance between the screen and the housing until the screen is only attached with 2 cables.
    • With the same plastic tool, disconnect the screen cables still attached to the phone.
    • The screen is now separated from the rest of the phone.
  4. Nokia N9 Battery Replacement, remove screws: 4 단계, 이미지 1/1
    • Unscrew the marked screws using the T4 torx screwdriver.
  5. Nokia N9 Battery Replacement, remove covering: 5 단계, 이미지 1/2 Nokia N9 Battery Replacement, remove covering: 5 단계, 이미지 2/2
    • You will see a strip holding the larger battery cover in place at one side.
    • Rotate the strip a quarter turn along the long axis, and lift it out.
    • Use the opening tool to lift the battery cover up and out.
  6. Nokia N9 Battery Replacement, replace the battery: 6 단계, 이미지 1/2 Nokia N9 Battery Replacement, replace the battery: 6 단계, 이미지 2/2
    • Click open the battery connector from beneath the connector.
    • Lift the battery from the phone and replace it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
knipwim
회원 가입일: 09/01/18
8,527 평판
안내서 30개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 23
30일 전: 45
전체 시간: 2,551
