필요한 것
Turn the phone around to the back. Some times the phones back camera slider will not work so if this situation comes about replace your back cover.
Your phone should now be able to separate into two pieces. One side being the back of the phone where the camera is located and the other being the side with the touche screen. Now that you have the two halves if you need to replace the camera any further you may either need to send the back of your phone to get repaired.
Back side of the phone where the camera is located
다른 한 분이 해당 안내서를 완성하였습니다.
