주요 콘텐츠로 건너뛰기
Nokia N900 USB Replacement
필요한 것
  1. Nokia N900 USB Replacement, USB: 1 단계, 이미지 1/1
    • Turn the phone over so the screen is face down.
  2. Nokia N900 USB Replacement: 2 단계, 이미지 1/2 Nokia N900 USB Replacement: 2 단계, 이미지 2/2
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  3. Nokia N900 USB Replacement: 3 단계, 이미지 1/1
    • Remove the battery by lifting it out of the device.
  4. Nokia N900 USB Replacement: 4 단계, 이미지 1/2 Nokia N900 USB Replacement: 4 단계, 이미지 2/2
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
  5. Nokia N900 USB Replacement: 5 단계, 이미지 1/1
    • You will now have two halves of the phone.
    • Grab the half of the phone that has the keyboard on it
  6. Nokia N900 USB Replacement: 6 단계, 이미지 1/1
    • Remove the keyboard by unsnapping the frame and then lifting the pad out from the device.
    • Place the key pad and cover to the side for the remaining steps.
  7. Nokia N900 USB Replacement: 7 단계, 이미지 1/1
    • Use a blue plastic opening tool lift the motherboard out of the back cover
  8. Nokia N900 USB Replacement: 8 단계, 이미지 1/1
    • Look at the bottom of the motherboard to find the:
    • USB Port
    • Once you've located the USB Port you can search online or call the manufacturer to replace it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Troy Posey
회원 가입일: 03/13/14
349 평판
안내서 2개 작성하였습니다
New Mexico State, Team 1-4, Easley Spring 2014 New Mexico State, Team 1-4, Easley Spring 2014 회원
NMSU-EASLEY-S14S1G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 16
전체 시간: 2,581
